Loss or water pressure and temperature water Heater.
Songbirds
Loss of water pressure and water temperature inside the Motorhome?
Here is what we found out as how-to-fix, the issue. At some point, someone (ME) had turned on the outside shower hose cold and hot water. The Problem was that I had turned off the water flow on the shower head (OUTSIDE), I had turned on the Value water, both Hot & Cold. Then turned off on outside shower head. Doing this kept the water heater set to a low temp. How to FIX. Go outside to the OUTSIDE WATER HOSE and turn off using the outside "VALUES" Hot and Cold as this will let water flow into the heater for heating. Turning water shower out off on hose caps for use only short-term. BUT ALWAYS TURN OFF OUTSIDE SHOWER VALES and not the SHOWER HEAD.
2021 Mercedes-Benz Sprinter Van, showing six tires down, 3400XD, V6, 7-Speed Automatic 24FL, 170-WB, 24'-3", Coachmen Galleria w/Li3, "Next ROAD TRIP" to where?
2 REPLIES 2
Artum_Snowbird
wa8yxm wrote:
Happens all the time... I have "Fixed" a couple of water heater problems by pointing this out to the owners.
The other common water heater problem is that some of 'em (not mine) have a check valve on the outlet.. IT "Limes" up and won't open to let water out.
Or it gets stuck open, then after draining the HWT and winterizing, the pink comes pouring out the opened up HWT which is on bypass through the stuck open check valve.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
wa8yxm
