โAug-13-2019 08:08 AM
โAug-17-2019 04:44 AM
rockhillmanor wrote:I think you handled your rear end sag in the best manner. Adjust the rear leaf spring pack to match the actual load.
What I did on my 32 ft that made a BIG difference in handling was I took it to a suspension shop and they did all this calculation figuring. I have quite a bit over hang from the rear axles back.
What they came up with was 'adding' one leaf to the leaf springs.
What a difference in handling, and as an unexpected bonus it lifted the back end and I now no longer bottom out/drag the hitch up and down those pesky steep gas station driveways.
Leaf springs are metal and metal fatigues. The leaf springs may look just fine but over time they are no where's as strong as they were when new.
Couldn't be happier with the add a leaf fix and it was not that expensive.
โAug-16-2019 05:02 PM
โAug-15-2019 03:56 PM
okiejoe wrote:Hi okiejoe, and also memtb,
My 32 ft class C E450 goes Dow the road like it is glued to it. But not when new, pretty much immediately after bringing it home I replaced original factory sway bars with Hellwig sway bars front and rear, Bilsteins shocks , Safety Plus Steering control, and Sumos to replace factory bump stops and then realignment, I can drive it with one hand and no stress. Try those mods. I am 68 and did all the work myself except alignment
โAug-14-2019 05:43 PM
memtb wrote:
Just yesterday, I installed our new Hellwig Sway Bars on our Ford E 450 (2006) chassis class c. It was easier than I expected, and going very well.....untill, when removing the last (very last) bolt. It was the last bolt remaining in the rear bar bushing mount and sheared-off the bolt when trying to remove it. After approximately 2 hours attempting to drill it out, and remove with an easy-out (not โeasyโ....failed), I drilled it out, and tapped larger to a 7/16 SAE bolt.
Going for a little test-run today....to see โifโ itโs โroad mannersโ are improved! Stiff and sore fingers crossed! memtb
โAug-14-2019 01:25 PM
โAug-14-2019 08:41 AM
โAug-14-2019 07:19 AM
โAug-14-2019 05:18 AM
โAug-13-2019 11:16 AM
โAug-13-2019 11:14 AM
โAug-13-2019 10:53 AM
โAug-13-2019 08:21 AM
โAug-13-2019 08:17 AM
