Mar-31-2016 01:38 PM
Apr-01-2016 08:49 AM
Effy wrote:
Welcome to the forum. I have found that Thor is usually very good about handling warranty and manufacturer related issues. I agree that waiting made it worse and they should have been contacted directly the first time. You are provided a concierge when you bought your coach and that's something that could have been remediated through them pretty quickly. Since it happened 3 times, make sure the sub floor isn't compromised as well. This issue may have grown due to the lack of immediate attention. Exposure to moisture multiple times may have exacerbated the issue. Just make sure you deal with Thor and they will fix it. AS others have said, taking it to the dealer should be fine. I am not sure taking it all the way back to the factory is necessary if you have a decent dealer to work with.
Apr-01-2016 05:51 AM
Apr-01-2016 05:39 AM
dougrainer wrote:
Being in St Louis, I would talk to your dealer and the Factory and arrange for the Motorhome to be fixed in Elkhart, Indiana if that is where it was built. I also do not understand 3 times????? Why did you allow it to happen 3 times? Did the dealer not find and fix the problem after the first time? Doug
Apr-01-2016 03:43 AM
Mar-31-2016 09:14 PM
Mar-31-2016 07:22 PM
Mar-31-2016 07:17 PM
Mar-31-2016 06:21 PM
Mar-31-2016 04:12 PM
Mar-31-2016 04:09 PM
Georgew48 wrote:fla-gypsy wrote:
If at all possible arrange to take it back to the factory for repair. It will get done better and in less time than the dealer IMO
I don't understand, if the factory was the one for the original poor quality how is taking it back to them going to result in a better quality fix?
Mar-31-2016 03:58 PM
Mar-31-2016 03:56 PM
Mar-31-2016 03:34 PM
Mar-31-2016 03:18 PM
Mar-31-2016 02:34 PM
