โOct-07-2013 02:29 PM
โOct-10-2013 05:53 PM
RVER wrote:
Well, I would NOT get a rig with a tag axle(two rear axles) because when you travel it much more for that extra axle on toll roads. Some poorly made rigs under 38 ft need the tag axle to hold the weight that the frame is not strong enough so they put it on a tag axle. YES you need tag axles on some bigger diesel pushers but I would not buy one of them either. IF you are going to live in the rig, you want a rig of GREAT construction, d0uble pane glass all around, extra insulation etc. In florida you need it to keep the rig cooler in summer. You would want 50 amp service if at all possible so you can run two a/c units at same time and hot water heater as well. Make sure your tires are less than 5 years old when you buy the rig since when it gets to 7 years you need new tires. Read the DOT numbers on the tire and the last 4 numbers will be the week and year the tire was manufactured. ex 1710 would be 17th week of 2010. IF there are only 3 numbers on the tires, that would mean they were manufactured before the year 2000. Rubber rot or not, new every 7 years, and RV tires are not cheap, can be $500 or more a tire. There are books written about full timing and how to budget for it, what it costs etc.
โOct-10-2013 05:45 PM
โOct-10-2013 04:32 PM
rollindowntheroad wrote:
I have been researching Class A's for when I retire to full time in. People have said that there are some built for full timing, but then don't say which ones. So, are there manufacturers or models that are built more full timing rather than just vacationing in? If, so please let me know. I want gas rather than a DP. I am not planning on traveling that much. Will be buying a used one.
It is just myself so I am thinking around a 35' would be fine for me. I live in Florida and plan on staying there, moving maybe every 3 months or so. Any recommendations?
โOct-10-2013 02:51 PM
RVER wrote:
Oh I am sure it is very nice but the weight driving around and the possibility of problems stops me in my tracks just as slide outs that are the length of the rig(1 long slide out) too heavy for the rails and they do have lots of problems. Saw a Thor yesterday that had two slides, one on the passenger side when from about 6 inches from front door, all the way back to back or rig so living room, kitchen, and bedroom was on one slide, on the other side were two slideouts, one in living room and the other in bedroom. The interior was HUGE, beautiful BUT I would not buy it, just too heavy for my taste. I do agree that to live in a rig, one must have room. IF you live in the rig and do not travel and do not open and close the slide outs but once or twice a year then YES I would do it but not if I am driving it a lot which one would assume one is doing given you have the motor to do just that.
โOct-10-2013 02:36 PM
โOct-10-2013 02:00 PM
โOct-10-2013 01:33 PM
โOct-10-2013 07:36 AM
RVER wrote:
Thunderingquiet I totally agree about Tiffin but as many slide outs is not a good idea, they weigh too much and each has a potential for failing.
โOct-10-2013 06:34 AM
โOct-09-2013 08:28 PM
prism wrote:
If your looking for a decent unit thats reasonable well built and has Factory support thats second to NONE Buy a Allegro bus.Tiffin warrentys everything about their coach for many years even if your second or third owner if its a manufacturer mistake on their part or something goes wrong that should not have.My unit is 6 years old.I bought it used and have had it for 2 years.The windshield poped at the two corners a few months ago.I called tiffin about it to see if there was anything I should look for when repairing it so i dont have a repeat.They said not that there aware of but they said get it fixed and they paid the bill. true story
The roof rails on some develop small vertical cracks.Again I,am taking it to a dealer near calgary next spring and it will be repaired for free under their warrenty.My Buddys 2009 had wiper arms break off.They sent him two new wiper arm assemblys free of charge hard to argue coverage like that.
โOct-09-2013 05:54 PM
โOct-09-2013 05:53 PM
Dick_B wrote:While researching my next motorhome purchase last fall, I went ahead and sprang $$ for RV Consumer's product. Didn't find it any more helpful than doing a lot of reading and asking around here and IRV2. RVCG does not consider my '03 Monaco Sig suitable as a full time rig. I know several here who would beg to differ.
Suggest contacting the RV Consumer Group www.rv.org for their more objective reviews of rigs for full-timing. They believe full-time rigs must have better than average systems and appliances.
โOct-09-2013 05:30 PM
โOct-09-2013 05:23 PM
super_camper wrote:dons2346 wrote:
There is no difference between a "fulltimer" and a "non fulltimer" rv. The difference is the manufacturers warranties. Some mfgs will not honor a warranty if the rig is used full time and as such is stated in the warranty. Most say that the rv is made for "recreational" use only. You have to read the warranty.
I would like to know if there is any truth in this?
I was looking through RV's at the show including the documentation and warranty and did NOT find any references to this anywhere.
โOct-09-2013 04:52 PM
