Massachusetts EZPass Transponder Mounting on my Class A
dmctlc
Where do folks mount their EZPass on their windshields for MA. and probably any state that has an EZPass system?
Thxs
Dana & wife Terri
Daughter - Stephanie
Granddaughter - Callie (9 y/o)
Son - Phillip
Granddaughter - Charlotte (1 1/2 y/o)
American Cocker Spaniel- Shadow
2018 Georgetown Series 5 GT5 31L5
11 REPLIES 11
sailor_lou
Mine is at the bottom center (about the same height as it would be in a car/pickup truck) and we have had no issues. Based on the responses here it appears both locations work fine.
Lou
05 Travel Supreme Envoy
turbojimmy
Top center of the windshield for me too. Works at the tolls and the high-speed lanes without issue.
1984 Allegro M-31 (Dead Metal)
Dale_Traveling
Top center also. And don't forget, if you bring along the toad with a pass remove it and wrap in foil or inside original RF shielded bag it came in so you don't get charged twice.
2006 Hurricane 31D built on a 2006 Ford F53
STBRetired
Top center of windshield.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Dr_Jay
Top center never had a problem.
2013 Winnebago Sightseer
Greater Boston Area
esyers
Ours is on the top center of the windshield......never had a problem.
Dutch_12078
sch911 wrote:
Ours is in the bottom center and has never failed to work correctly.
X3
Dutch
2001 GBM Landau 34' Class A
sch911
OEM Auto Engineer- Embedded Software Team
jplante4
Both EZPass and the Sunpass from FL are mounted on the bottom of the windshield on either side of the center. Works just fine there.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Sam_Spade
Thxs
With a class A, I don't see why the question.
Why not near the top of the windshield in a fashion similar to a car or truck ??
Now.....with a C that has an overhang, I've found that mine works OK at the BOTTOM of the windshield, where there is a clear line of site to the reader devices mounted overhead.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
rk911
Thxs
I put our Illinois I-Pass transponder against the top of the cabinet in front of the driver's seat. the cabinet has a "fuzzy" lining and the Velcro strips on the back of the transponder attach quite well to that material. I-Pass is compatible with EZ Pass and we've not had a problem traveling thru any EZ Pass state.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
