โMar-21-2017 08:12 PM
โMar-22-2017 11:18 AM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โMar-22-2017 11:06 AM
โMar-22-2017 10:15 AM
โMar-22-2017 09:34 AM
10forty2 wrote:
Do I need to say it too? Probably not, but I'm going to anyway... ๐
Alignment issue, most likely tow-in adjustment. Your tires are riding on the outer edge and not the full contact patch as with a proper alignment. That's what's causing them to wear out prematurely on the outer edge. It's not the tire's fault.
โMar-22-2017 09:33 AM
Executive wrote:
rk911, I've run Michelins and Goodyears. Both performed well. Had one GY suffer rivering but all others are good. Since you're experiencing uneven wear on both sides, that indicates an alignment issue. While bad shocks will wear your tires too, usually that will result in bump on the tires that you can feel. Before you make the decision on tires, I'd invest in a alignment check. Fix the problem before you give up on any tire mfg. I'm not knocking Roberts Tire, but use caution when purchasing from them. Especially the Power Rd. shop. A lot of those tires sit in the hot Arizona sun for a long time. Insist on fresh tires.
I'd also recommend Spectrac Alignment shop, 405 E Baseline Rd, Gilbert, AZ 85233
Phone: (480) 545-5533. I've used them twice and found them to be reasonable and very knowledgeable. They are on Baseline just off Mesa Drive near La Mesa RV. Call them and explain your situation, or stop by with some pictures and get their opinion....BOL....Dennis
โMar-22-2017 07:32 AM
โMar-22-2017 07:26 AM
Several folks in the park who claim they have the necessary experience tell me it is not an alignment issue, not the fault of the steering stabilizer but rather a poor tire.
โMar-22-2017 07:04 AM
โMar-22-2017 07:01 AM
โMar-22-2017 06:37 AM
โMar-22-2017 06:22 AM
โMar-22-2017 06:01 AM
โMar-22-2017 05:26 AM
โMar-22-2017 04:55 AM
