Monaco Roadmaster Chassis... Need Info Please
Nutinelse2do
Looking for information on Roadmaster chassis...
We know there are 3 service centers in the entire US, but....
Where do you take a Monaco for chassis inspection prior to purchase? Do you have to go to Tx, Or, or Indiana?
What happens if you need a part for the air ride suspension? Looking at a coach with the RR10S suspension.
What have you Monaco owners experienced trying to obtain parts or service when you are 100's or thousands of miles from an authorized service center?
Thanks for your responses.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
8 REPLIES 8
Campinghoss
Twomed wrote:
Campinghoss@51 wrote:
Prior to purchasing ours we took it to a Cummins Service Center that had coach care. We had the new correct trailing arms installed and a bumper to bumper inspection. That included ride height adjustment, shocks, and engine, transmission inspection. We have been very satisfied with their service. They have facilities all over the country.
Trailing arms issue does not apply to RR1O chassis. ๐Ÿ™‚
Yes I know. I just wanted to let the op know coach care could do the majority of chassis work.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
Twomed
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
William_B
We have never had any problems getting service done to our chassis. You don't say where you are or where you'd like to have it inspected. Would be easier to zero in on a good shop familiar with the chassis if you did.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
Campinghoss
Camping Hoss
Lucie our fur baby
bullydogs1
There are plenty of answers to get Monaco parts and the support guys in Oregon can even tell you their supplier to bypass getting them directly from Monaco themselves and go to their supplier....Also Alliance Coach in Wildwood Fl used to be the old Monaco factory service center for south and they know the coaches cold. Plenty of service and knowledge is out there for the true Roadmaster chassis setup...no worries at all. If you call Monaco themselves with the coach number/VIN, they can send you a build sheet showing you the source and serial number for everything in the coach.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
DSDP_Don
The front end and read end are standard and still available units. All the other parts, like bushings are available. The few parts that aren't available, rarely have issues, and if they did, they would be repairable, ie...straightened, welded, etc.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Twomed
115k on ours... only parts needed have been easy to obtain.
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
gemert
Any good RV chassis or truck shop can fix the chassis. It's not anything unique. The trick is finding a "good" RV chassis or truck shop. Some truck shops just don't want to mess with RVs.
Jerry
Chief USN Retired
2003 Beaver Patriot Thunder C-12 505HP
2004 Dodge Ram 1500 4X4
