Monitor panel question
Coach_Cleats
The lights for LPG, Holding tanks etc. are not illuminating/working. Replaced toggle switch but same problem. Can someone guide me to the next step?
2004 Safari Cheetah 36 PDD, 03 Wrangler Sahara Toad W/Buddy Brake.
Denise and Bob 70 Years as Teachers!
Kodi D'dog'.
About to play as long as we worked.
Senior Softball! What a blast. Nothing is routine!
5 REPLIES 5
DrewE
Have you pulled the monitor panel and seen if there is power getting to it (I would guess to the switch you replaced)? Have you verified that you connected the replacement switch properly, and didn't accidentally connect to the NC and NO contacts but not the C (or something similar)? Does it work if you jumper the switch?
If there's power through the switch, then it would seem to me that the most likely culprit is the wiring between the switch and the monitor panel circuit board, or something on the board itself. Maybe there's a cold or cracked solder joint where the power or ground attach to the circuit board.
Coach_Cleats
On shore power and no fuse that I can see based on Monaco electrical manual.
Kodi D'dog'.
Coach_Cleats
I am on shore power and cant find a fuse based on Monaco electrical manual.
Kodi D'dog'.
jvowell1
If my house batteries are low mine won't light up
rk911
fuse? circuit breaker?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
