motorcycle carrier
ricelake922
I have a 1996 Monaco Dynasty and want to put a carrier for my Suzuki Bergman 400 which weighs 460 lbs using a carrier model number SMC-600 supplied by Rage Motor Sports. Has anyone had any experience with this carrier or any comments or suggestions are always appreciated. Thank you in advance.
4 REPLIES 4
Two_Jayhawks
Here are some reviews if you haven't already read them.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
TNGW1500SE
krivanj wrote:
I have used a Versa Haul for a KLR. I don't know this carrier. 460 lbs is a lot to push up a ramp.
Versa Haul makes a good product.
EV2
Have a Yamaha Majesty that with the carrier is at 500# works well and easy to use scooter running to climb the ramp. Better yet, loading and unloading next to a gentle uphill slope away from the coach makes it super easy. Also, in addition to a set of standard tie-down straps, the Canyon Dancer bar harness really assists in stabilizing and quick, stable tie-down.
6000 secure miles.
krivanj
Fleetwood Revolution LE 38X
2011 Scion TC toad
