Mar-21-2014 11:30 AM
Mar-30-2014 01:54 PM
Mar-23-2014 12:33 AM
DSDP Don wrote:
Kluckraft.....If you order the new PacBrake PRXB, order the two clamps that hold it on.....often the old ones have had it and the new ones are easier to work with. If you can access your exhaust brake, installing a new one is pretty simple.
Mar-22-2014 04:36 PM
Mar-22-2014 12:56 PM
Kluckraft wrote:
Thanks for all of the input...I am going to try the Pac Brake upgrade to my original OEM exhaust brake. Again thanks to all and safe travels.
Ken
Mar-22-2014 12:34 PM
Mar-22-2014 10:41 AM
mtrumpet wrote:
If you're unfamiliar with the Air Brake Test, here it is. This is the standard proceedure. (This was posted by foosh1 here on the forum back on 3/2/10)
1) Start vehicle and let pressure build up to proper level (usually 120 psi)
2) Leave parking brake engaged, put trannie in D and gently press the accelerator. It's called a tug test, and parking brake should hold the vehicle.
3) Stop engine, but leave key in whatever position that allows you to read your air pressure gauges, chock vehicle if necessary and release parking brake.
4) Press brake pedal very hard and start timing one minute. Watch gauges and check to see you don't lose more than 3 PSI in one minute (4 psi for a combo vehicle). Listen for leaks.
5) Start pumping the brake pedal rapidly, and you'll hear air bleeding off. When PSI drops below a certain level a warning buzzer should sound, and when it drops a little lower the parking brake will automatically pop out. (This is a safety feature that allows you to stop if you were to lose your service brakes).
6) You're done.
NOTE! It is very important that you NEVER press on the brake pedal hard while the parking brakes are engaged. You could damage the springs that operate the parking brake system!!
Mar-22-2014 10:17 AM
Kluckraft wrote:
I have a 40' 2002 Beaver Santiam. I have never been entirely pleased with its braking capability. We are about to travel to the 5 National Parks in Utah and I was wondering if anyone has any suggestions as to how I might improve on my motorhomers braking capability so I can handle the long downgrades with more confidence. By the way, my tow is equipped with Air Force One. Thanks for your help.
Ken
Mar-22-2014 10:15 AM
Mar-22-2014 09:16 AM
Kluckraft wrote:
Thanks. I do have an exhaust brake which helps a lot, and I have hade the pads and air recently checked. The problem I have is on long, steep descents the brakes get very hot (smoking hot), and begin to fade. This is with the exhaust brake on and in low gear.
Ken
Mar-22-2014 07:10 AM
Mar-21-2014 11:35 PM
Mar-21-2014 10:38 PM
Executive wrote:
On my Dynasty, I dumped the OEM exhaust brake and replaced it with the PXRB from Pac Brake. By far, the BEST upgrade I ever did. The difference was night and day. Spend a few bucks and upgrade....you'll thank me afterwards.....Don't wait too long to apply the EB. Lots of folks wait until their speed is too great before applying the EB. This means the EB does not engage. If 50mph is your comfort zone, apply the EB near the top of the hill just as you start down. The tranny indicator should show 2,3 or 4 depending on how it's programmed...yes, it can be changed. This does not mean your tranny has shifted, it simply means when your speed comes down it will lock in at that gear. The allison will not let you overrev the engine. If you begin to exceed your comfort speed, STAB the brake pedal and release. Do it as often as you need to in order to bring your speed down to your comfort level again. I rarely used my service brakes after the upgrade to the PXRB. ...Dennis
Mar-21-2014 08:10 PM
Mar-21-2014 07:55 PM
