Motorhome Entry Steps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โJul-09-2015 04:49 PM
Does anyone have a suggestion as to how I can get a "schematic" on these steps? It seems most of these steps operate about the same.
Any help will be appreciated.
2013 Jeep Sahara 4-dr w/M&G Braking System
Roadmaster Blackhawk 2 All Terrain Towing System
- Labels:
Class A
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-10-2015 03:02 AM
Upgraded with a 08 HR Navigator 45โ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 08:04 PM
Assuming you have Kwikee Steps and that you have good voltage from both battery systems, go to the search box and type in "Kwikee Steps" .
Search at least a full year. There should more than one link for the #888 manual. Or you can Google, Kwikee Manual #888. I'd give you the link if I was at home but I don't have it in favorites on this computer. You don't have to disconnect your battery, first of all if you do, you can't follow the trouble shooting instructions because they are all for the electrical systems.
Sometimes when the steps are so far closed or open you won't be able to remove the clevis pin on the actuation arm at the step. My suggestion at this point is disconnect the motor leads and remove the ENTIRE motor assembly including the mounting plate. There are only four 1/4-20 nuts to remove and the entire assembly falls out. Then you can test the motor easily at your bench.
The ideas about cleaning and lubing are well founded and I would bet most failures are caused by improper preventative maintenance. I use Kwikee Lube and it works well. I relube on the road if I run into rain or dirt roads, both gum up the lube.
Good luck and let us know it come out.
PS: Check Chris Bryant's web page, he has tons of manuals just for the asking. Also 2008 is about the time US Gear bought Kwikee but if they are labeled Kwikee the give you #888 manual will give you the trouble shooting procedures. If you have a gear housing that is part of the motor, it was made by AM Machinery in Oregon, they have made sales directly to RVers at a really great price.
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 07:33 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 07:12 PM
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 06:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 06:39 PM
There's a number of issues that plague those steps. As has been stated, a periodic lubing of all the pivot points is warranted to keep things moving as nicely as possible. Another problem of course is the small motor. They have lots of issues. They can freeze up due to corrosion (although it doesn't happen all that often) The brushes can get corroded over and will not have good contact with the commutator ring.
The gear box is also known to cause problems. If the gears in there are worn to a point that a tooth breaks off, it can lodge in between the drive gear and, the driven gear. The link-arm can get seized up in its pivot points too. The connections to the motor, although are fairly sealed up, can on rare occasion, also get corroded.
All of these various issues have caused problems to many folks. If I had to guess, I'd bet right now that your issue is not caused by the pivot points locking up. While it does make things work more smoothly when lubed, to completely lock up a set of steps because of non-lubing for a length of time, is not very likely.
The problem with your situation is, the steps are in the retracted position and, that makes for hard to get to components to be analyzed for correct working operations.
There is either a bent or, straight "link arm" that connects the motor to the gear box in your steps. What you need to do is, do the best you can to disconnect that link arm, while the steps are in that retracted position. Once that's disconnected, the steps will fall, due to gravity. Be prepared for that. But, once they're free from the connection to the motor and gear box, you can pivot them out of the way, so that you can start your analyzing of other components.
And, while you're at it, and, they're disconnected from that link arm, you can see just how free they move or, don't move. Good luck and please report back to what you find. Good luck.
Scott
SDFD RETIRED
KI60ND
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 06:25 PM
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 05:46 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 05:17 PM
wildtoad wrote:
First thing to do is to lube everything. A lot of time the unit will fail if if detects too much resistance. When you open and close the door do you hear anything clicking or trying to move?
x2. Use compressed air and whatever it takes to clean all the joints. Then lube well. Use penetrating oil, not WD-40.
If it turns out to be an electrical problem, you'll have the cleaning and lubing done.
Please, let us know the problem when you get the steps working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-09-2015 04:56 PM
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
