Moving Winguard Traveler
bluwtr49
If I want to move my dish further back on the coach roof....say 4-5 ft can all the cables just be extended???
Thanks for any input.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
8 REPLIES 8
Dale_Traveling
rgatijnet1 wrote:
The Winegard came with two very long cables for the coax and the control so the extra is probably coiled up somewhere inside of your coach. I doubt if anyone cut the control cable since it has connectors on each end. If they did cut the coax, it would be easy to add an extension cable.
Last owner had the sat antenna install on my coach and there's about 10' of coiled wire, coax and control, up behind the TV above the dash in the front cap.
2006 Hurricane 31D built on a 2006 Ford F53
Bill_Satellite
Do not try to add an extension to the control cable. It comes 30 feet long and there should be extra you can pull and use as it exists unless this was installed while the coach was being built at the factory. It's unlikely there is excess coax but you can simply add an extension as you have planned.
Can't we all just get along?
DSDP_Don
I think I would remove the plate on the roof that covers the cables (about 6 screws) and see if the excess cable has been tucked away and easily pulled out. The less coax connections, the better the quality.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
bluwtr49
Darn, I really had planned on moving the holes....reckon thats out.
Regarding extending the wires and such, I was sort of planning on moving the unit than make up new extension pieces on the roof rather than trying to pull the wire back up from the cabinets.
Dick
rgatijnet1
Effy
This is a question no one can answer except the person that installed your unit. If you have 4-5' of slack, then yes, otherwise, not without adding additional wires/cable. My guess would be they didn't leave that much extra wire when they chased it.
2013 ACE 29.2
SnoBear
"Yes, but you won't be able to move the holes"
Why not? They're not very heavy ...
Executive45
Yes, but you won't be able to move the holes....:E.....Dennis
