my 1989 chevy coil springs need replaced on my chassis p30
clarencecnj
Hi there. My name Clarence nobles. I just sign up on here thought maybe i could post but can not figure out how to. I need to find someone that knows about my mobile home rv. My problem I am having with it is that The back is riding way to low and I done know my coil springs needs replaced but I can not find no one no web sights no parts stores no where at all has them for the rear only the front ones. i need the rear ones. My rv is a 36 feet 1989 Brovo Chevy P30 When they type that in it shows only the front not rear that I need Theres no part number on the old ones also. where and how do I post here this and see if anyone can tell me what to do to find these. or can you maybe help me with this please. I can send add photos if I need to.
I need to find these coil springs money is not a problom
9 REPLIES 9
cross_country
I also have coil spring suspension (P-30) with the mor ryde tag set up. No question, air bags added to the drive axle will enhance the performance with an ability to; level, and adjust with full tanks. I used Firestone Ride Rite air bags for the rear, a little tricky for clearance, make sure they don't rub or have the possibility of coming in contact with an abrasive surface.
Mary and Tom '86 Crosscountry Sportscoach
2000 Foretravel U320 4210
Argosy24
Mor-Ryde tag did use coils and rubber blocks for suspension. Make sure those aren't torn up also.
Tim_Nowicki
Doug
My P-chassis Pace Arrow has coil springs in the rear. It has MOR RYDE. they install them with that suspension.
Tim
wolfe10
Yes, there were some aftermarket transversely mounted helper leaf springs for the P 30.
I would get with Henderson AFTER weighting the front end so you are able to get the correct springs (no air bags needed) for your actual "going down the road" weight.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
dougrainer
I have never seen COIL springs on the rear of a P30 chassis. LEAF Springs only. Which you can either re arch or add a leaf. Some P30 did have AIR Bag systems added on in the rear. Can you take a pic of the Coil springs? I wonder if someone jerry rigged a coil spring on your RV over the years. Doug
BobandShaz
Leaf springs also?
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
IAMICHABOD
That is odd that you would have coil springs on the rear of the P30 chassis, unless they supplement the leaf springs.
My old 89 P30 chassis Winnebago was a tail dragger too and I fixed it by putting Hellwig helper springs on it and also a set of air bags and that fixed it.
The Air Bags helped a lot when towing my Desert Toys.
The local Truck spring shop was way more expensive and would not guarantee that what I told them to do was enough or to little.
Hellwig Helper Springs CLICK HERE
Air Lift air bags CLICK HERE
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Mandalay_Parr
I would take it to a truck spring place and let them have a look.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
rgatijnet1
Contact this place:Hendersons
