My Tub Issue Rides again!
Mrsmoos
Do you all remember my bathtub that seems to have settled? Here are some pics of what I could see behind the access panel. It all looked really good to me and hubby couldn't see anything that looked like rot etc. It looks like it may have just "settled." The dark areas you see in pic with the vinyl flooring showing feels like the vinyl adhesive seeped out maybe? Its very hard.
So anyone have any ideas to "jack the tub" up? (Included a pic of the tub problem)
7 REPLIES 7
Mrsmoos
Found response from darsben
Mrsmoos
Strabo wrote:
We just went thru this last year. You have to build up the sub floor to support the entire bottom tub, we also replaced the tub portion because it was cracking alot. Much more solid now and usable, no leaks.
STRABO--did yours have a glass enclosure? Ours does. I would dearly love to pull the whole shebang our and replace the tub/shower walls but I don't think I will be able to convince my Hub to do this. Is it a real big ugly job? I want it to be sturdy enough for him to use and he is about 100 lbs more than me.
crasster
Ok, I'll just tell you what I would do and it's not the "exact perfect way" but I think it would really work.
I'd go buy several rubber shims or PVC shims. I'd stick SEVERAL under it in multiple places. Get a solid foundation of support.
Then I would buy the expanding foam "great stuff" and spray it in all the nooks and crannies (avoiding drains and cracks). The foam expands well and is fairly solid. It may back up the shims for support especially with the expansion. Think of it like a solid platform of hard foam with many heavy supports through it (shims).
Anyway, that's what I would do. Unless you can find a very solid thick piece of rubber and cram it there underneath.
Anyway, THINK SUPPORT.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
darsben1
I used Luan plywood to raise the tub.
See my previous post
Traveling with my best friend, my wife in a 1990 Southwind
Strabo
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
2gypsies1
..a jack?
Full-Timed for 16 Years
.... Back in S&B Again
SoCalDesertRid1
Maybe it can be shimmed up with some thin wood between the tub bottom corrugations and the subfloor plywood?
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
