Mine in my Fleetwood was intermittent but different symptoms. Mine would blow ice cold for 20 minutes to a few hours then quit blowing cold like you pushed the ac button off. Fan still blew.
It was a bad thermostat.
I called Fleetwood and they emailed me PDF files for the system. It is a Denso. It had a trouble shooting matrix.
My system does not have an inspection window. Your gauges should tell the story on it being empty. Your dryer may be full and you may have non-compressible moisture in the system. You need to find the leak to properly fix it.
And hate to tell you, nobody can give you a firm estimate without troubleshooting it first, which may places don't do free anymore. Most will apply it to the total.
My Kharma ran over my Dogma.
