โMay-19-2014 08:12 PM
โMay-27-2014 10:02 AM
tpi wrote:
Can you give the numbers read out by the smog test? Did it flunk the idle portion of the test? By how much? When the manifold was glowing red during the high speed portion, did it flunk that too? For what reason? Nox?
In general, leanness should not cause manifold to glow just by revving up engine to about 2K RPM in neutral. The symptom for leanness there would be lot of popping and rough running as the engine was at that speed with low load. Is the engine running smoothly at the 2K RPM portion of test without popping in exhaust?
A gut guess the red hot exhaust was not related to the carb. Either timing effectively retarded for some reason (more to it than just idle static timing), or restricted exhaust come to mind. The one place where it may be carb related is if it has Air Injection Pump and the rich running engine is causing excessive afterburn in the exhaust manifold.
But to start post your results numbers.
โMay-26-2014 09:41 AM
โMay-26-2014 12:00 AM
โMay-21-2014 10:59 PM
โMay-21-2014 08:41 PM
Mbrown wrote:
Well upon further research and discussion it turns out its an distributer/carbuerator issue
โMay-21-2014 07:52 AM
โMay-20-2014 10:27 PM
โMay-20-2014 09:23 PM
Mbrown wrote:
Have been researching this topic of glowing exhaust on line and some say too rich, others too lean, also possible causes are; catalytic converter clogged, o2 sensor, throttle position sensor, cracked manifold or timing. The timing was off 3 deg but dont think that was problem...
Where to go next ???
โMay-20-2014 05:27 PM
โMay-20-2014 10:32 AM
โMay-20-2014 07:29 AM
โMay-20-2014 06:49 AM
โMay-20-2014 03:05 AM
โMay-20-2014 01:22 AM
