Noisy Dometic Air Conditioner
snoopeme
I've had a 2014 Unity by Leisure since it was new and have always thought the low profile Model 651916 Dometic A.C. was awfully noisy! I mentioned it to the dealer (La Mesa RV) while it was still under warranty and he laughed and said they all are noisy! Well I don't think so!! I took off the inside the coach trim and have found about 1/16" play in the blower's squirrel cage and am thinking this might be the problem? What do you think? I am on the road and not able to get up on the roof to investigate further topside....and unfortunately it looks like it takes a very long Allen wrench to reach the set screw holding the blower to the shaft...which I also do not have with me! Has anyone faced a similar noise problem and do you have any suggestions or encouraging words? BTW, I have run the fan only without the AC and it is still noisy! Snoop
2 REPLIES 2
ronfisherman
Moderator
Moderator
Same problem with a friends motorhome. Found that fan had become loose from motor shaft. While tightening up screw. Found fan had been hitting a panel inside AC. Moved fan over a little to stop it from hitting.
As already stated. Make sure power is off before attempting repair.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
want-a-be
We thought the same thing about the noise. Ask about it when we had it back at the manufacture and was told they all make different type of noise, about a year later the blower came apart, talk about noise I thought the roof was coming off!
I unbolted the motor and lifted it out to work on it. Make sure the breaker is off so it does not start.
Good Luck
