Norcold Fridge
ubeenhere_com
My Norcold fridge has power and lights up and The freezer works fine but the Fridge does not get cold on AC or LP. thoughts? Any Suggestions?
4 REPLIES 4
JR45
I see a Samsung 197 in my future.
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
MaverickBBD
If you do any research on this topic, you will find the bottom line is probably going to be replace the cooling unit with an Amish cooling unit OR go to a residential fridge.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
Coyote74
My
1200 lrim had a great freezer 10 below. Ended up replacing the cooling unit, i Did have an extended warrany. Close to 1900.00 bucks
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
robsouth
How long has it been on? Most take 12 hours or so if empty, some longer. If full of non "pre chilled" stuff" it could take days.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
