ONAN 5500 Grand Marquis fuel pump & filter
drifterpilot
I have the Onan 5500 Grand Marquis generator on my motorhome.
Model# 5 . 5 H G J A B - 1 0 8 C
I want to replace the inline electrical fuel pump and filter on the generator.
The part number on the fuel pump is Cummings A O 2 9 F 8 8 7. This number has been discontinued.
Does anyone have good part numbers for these two items?
Cummings or other after market part numbers??
I could use a part number for the carburetor also.
Thank you.
2017 Allegro 34P
7,900 Miles, Ford V10
Winegard (in-motion tracking)
Blue Ox Avail
Brake Buddy
6 REPLIES 6
2manytoyz
I posted a video on YouTube where I replaced the fuel pump and filter on mine.
https://www.youtube.com/watch?v=nyHNPczC2YQ
I bought the replacement pump ($34.95) and fuel filter ($17.48) on Amazon.
Fuel pump: https://amzn.to/2UZjVRt
Fuel filter: https://amzn.to/2GxDSM7
Pretty easy job. Watch the video first if you're unsure.
Robert
Merritt Island, FL
2023 Thor Quantum KW29
2006 Jeep Wrangler Unlimited TOAD
2023 Jeep Gladiator Rubicon TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
apr67
You can get the OEM Onan one from PPl motorhomes for $82. I bought the Airex from Amazon. Mine failed after 40 days, in the same way as yours is currently failed, overheats after a few hours and then if it cools it works again. Tried to use the warranty, well their is no warranty, because the warranty has to be honored by the seller and Amazon won't take it back after 30 days.
They also have the fuel filter.
https://www.pplmotorhomes.com/parts/rv-appliances/generator/permanent-generators/permanent-generator-replacement-parts/cummins-onan-fuel-pump-a047n929_49-7991?gclid=EAIaIQobChMI2YqipvH14wIVmpOzCh3YuwywEAQYBCABEgIoKPD_BwE
https://www.pplmotorhomes.com/parts/rv-appliances/generator/permanent-generators/permanent-generator-replacement-parts/onan-fuel-filter-149-2341-01_68657
2017 Thor Hurricane 34J
Gone-2014 Chevy Express 3500
Gone-2016 Jayco White Hawk 32DSBH
Gone-2013 Keystone Bullet 294BHS
Gone-2007 National SurfSide 34DE
Gone-2006 ForestRiver Sunseeker 2900LTD
Gone-1994 Fleetwood PaceArrow
Gone-1978 Kit RoadRanger
IB853347201
Just Google "fuel pump for marquis gold 5500 gasoline/hgjab", and several links will come up including Amazon.com which lists replacements starting at just over $20.
Same for the carburetor. Amazon lists Cummins 5410765 Onan Carburetor Kit as the replacement.
2010 Suncruiser
MountainAir05
just about any pump will work. Just keep the pressure out put low. Its either 3 or 5 lbs max. Sure someone will jump in .
This is what I got many years ago when I needed one right now. Been working since.
https://www.amazon.com/Bravex-Universal-Pressure-Electric-HEP-02A/dp/B01NA6AEXC
GREGORYJ
I got a fuel pump and filter off Amazon.com a few years ago and is still working fine. My fuel would stop(seize) when it got hot causing generator to stop. It
would work again once it cooled but stop again when hot. In cold weather it would work better.
https://www.amazon.com/s?k=onan+5500+fuel+pump&crid=VQGILPQ11T1L&sprefix=onan+%2Caps%2C286&ref=nb_sb_ss_i_4_5
Ellen & Greg
08 National Dolphin DL-35Ci, Kelderman Air Ride, Rear Trac Bar
Workhorse W22, RoadMaster Rear Sway Bar, Towing 08 Smart Car
ArchHoagland
I'm curious why you are changing them.
What kind of problem are you seeing and also how many hours are on the generator.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
