Onan 7500 quiet diesel
iamalienru
I recently drained the radiator fluid in my onan 7500 as general maintenance. When I repaced the fluid it seemed to take only about a quart of fluid I am pretty sure it is suppose to take about 4.5 quarts. Anyway now when it get up to temp is shuts off. My question is...is there a fluid bleeder on the block of diesel engine? I feel like I could have some sort of air trapped that won't allow the extra fluid. I have read all the posts on the temp sensor and belts to the pump. I just can't figure out why all of a sudden it won't take anymore fluid and if for some reason it is full why it is shuting down
Tom
22 REPLIES 22
John___Angela
RLS7201 wrote:
iamalienru wrote:
I did get the capacity from the panel. I did not get 4.5 quarts from the drain. This could because the overflow tank was clogged and not sending extar fluid to the radiator. It has been cleaned and there is now flow. I bought this coach in Jan. of this year. It seems there may have been some neglect on maintenance. I left the cap open overnight hoping it would burp out any air bubbles but it didn't seem to do much. I will probably take a lazer temp of the engine before changing out the high temp sensor or thermostat the water pump and belt seem to be in good shape. I was hoping someone was very familar with this engine and could let me know the best way to remove air pockets
I tried to tell you how to fill the engine with coolant by providing the Youtube video.
You didn't fill the engine in the proper place. Find the radiator cap under the cover and fill it there.
Richard
Second this. I've changed ours a couple times. You need to fill at the cap, not the reservoir.
Good luck. Let us know how it goes.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
FIRE_UP
iamalienru,
I was just wondering, I don't know if you know anything about the "Codes" that, that gen can throw out if, and when it has operational issues. If you're not familiar with them, the codes show up as a sequence of blinking of the LED light, in the on/off/start switch of the gen itself.
When your generator shuts off on its own, is that switch "blinking" in any form of sequence? That is, something like three flashes, a short pause and then three flashes more, then a long pause, and the sequence starts again?
Scott
Scott and Karla
SDFD RETIRED
KI60ND
Laman
Do yourself a favor and go to that link provided above for the how to video on youtube. Follow these instructions and I bet your problems are solved
1998 American Eagle 40' EVS, 2011 Ford Edge, Falcon 2 tow bar
DW and 2 DD's
iamalienru
Tom
RLS7201
This Link should help you correct the problem.
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Big_Katuna
The capacity is listed on the info panel by the switch. QDs are hard to fill, like burping a baby. You have to fill throughout the cap, not the tank. I used a small hose,1/4 " or so and a small funnel. Needs to trickle in.
My Kharma ran over my Dogma.
2ndhom
Did you drain out 4 1/2 quarts??
