Aug-05-2015 08:10 AM
Aug-06-2015 06:52 AM
JumboJet wrote:wildmanbaker wrote:
Not the wiring plans that Fleetwood will send you, but the build/repair plans that are used to build the MH, and RV techs use for repair. Before just replacing the batteries, use a hygrometer to test the cells. Use a manual charger overnight, and test again after an hour of rest. If the hygrometer and a voltage test are good, a load test can be performed. If the batteries are good or replaced, you really need to find out what the hidden loads are, to prevent draining the batteries.
Batteries are swollen and leaking acid out the top. The engine starting batteries are relatively new. The previous owner (has had coach since 2006) does not know the age of the Trojan T-105 6 volt batteries. I do know they will not hold a charge and will not start the generator unless the coach engine is running. The previous owner kept a trickle charger on the batteries.
I figure when you turn the switch off to the batteries, they should maintain a nominal charge enough to crank the generator within 24 hours. They are not doing that.
Aug-05-2015 07:59 PM
Aug-05-2015 06:52 PM
JumboJet wrote:
Specifications:
Motorhome - 2003 Fleetwood Expedition 34W - Cummins 5.9 ISB
Generator - Onan/Cummins Quiet Diesel 7500
Which battery group is best to use to start the generator? Engine batteries? House batteries?
Issue #1: House batteries are used for 2000 Watt Inverter. Generator will not start when house batteries are at 10 volt cutoff to the inverter.
Issue #2: House batteries are being replaced and I wonder if it would not be best to move the generator start cables to the engine batteries, OR install a separate battery for starting the Onan generator and provide a charging wire from the engine alternator?
When the generator is powering the Xantrex Inverter/Charger, the house batteries would be re-charging.
Aug-05-2015 06:47 PM
Aug-05-2015 05:46 PM
Aug-05-2015 05:42 PM
ksg5000 wrote:
I got stranded once with dead chassis and coach batteries ... after that I moved everything that was attached to the chassis battery to the coach battery. I also got in the habit of starting the RV before I tried to start the generator - that put all the batteries on-line and generator seemed to start quicker and didn't tax batteries as much.
Aug-05-2015 05:10 PM
Aug-05-2015 11:07 AM
wildmanbaker wrote:
Unless you have a COMPLEETE set of 12 volt wiring plans, I would be very shy of re-wiring a MH, as you could miss something important, that could cause a fire down the line.
Aug-05-2015 10:40 AM
GrampaR123 wrote:
tropical36?
Actually, don't you have that reversed? Doesn't the "battery boost" switch you refer to allow the "house batteries" to assist the engine starting battery when it's too weak to start the engine?
Maybe I've had the wrong idea all these years.
Aug-05-2015 10:37 AM
Aug-05-2015 10:09 AM
Aug-05-2015 08:55 AM
Aug-05-2015 08:50 AM
Aug-05-2015 08:39 AM
JumboJet wrote:
Specifications:
