RLS7201 wrote:
I've seen this rationale many times. But why would fuel tank level affect fuel pump temperature if the pumped fuel flows through both the pump and the pump motor housing?
Richard,
The fuel pumps to which they are referring are inside the gas tank. By keeping the tank level high, the gasoline surrounding the pump acts like a heatsink to keep the pump cooler. If the gasoline level drops below the top level of the pump then the pump will run warmer because of the loss of this cooling action, potentially accelerating wear and increasing the likelihood of pump failure.
To that, the other variable I'd add is to make sure the gasoline stays fresh in the tank and to add fuel stabilizer if the fuel will sit in the tank for 6 months or more. I find this especially true for my small gasoline engines, and wonder if the fuel pumps could also be effected by a build up of varnish. The price of a bottle of Stabil is cheap compared to a new fuel pump and installation. Pluse the Stabil helps keep the generator fuel system in top shape too.
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
