โFeb-04-2018 01:51 PM
โFeb-06-2018 05:18 PM
โFeb-06-2018 01:45 PM
โFeb-06-2018 06:09 AM
ryegatevt wrote:Yup. Best to just ignore.
Hmm.. The OP joined the forum and posted this fantasy on 2/4/18. You don't suppose this guy is a troll with lots of time on his hands, do you? Each of his comments just keep getting weirder and weirder as they go along...
โFeb-06-2018 05:44 AM
valhalla360 wrote:
WOW!!! Almost hope the authorities catch on to you now.
โFeb-06-2018 04:14 AM
โFeb-05-2018 09:30 PM
Caleb Volksa wrote:
I was either thinking use a modified Diesel tank, the kind that is mounted to the frame. Drill a 4 inch hole in the bottom, weld a pipe to that, put a flange on a lever in it and put a lock on that so some kid can't dump my **** all over a parking lot or whatever. Get one of those sewage hoses and dump it in his septic tank or I was also thinking about checking out the stream near where I wanna clear cut trees and build a campsite, it's pretty close and I could bury some 4inch Pvc pipe and use that as sewage to the stream.
I wanna build a nice water wheel and a bridge up stream for extra electricity, dig a pit in the stream install a bucket half filled with rocks and a pump with a good enough filter up stream so if I run out of water I can still shower and use my toilet, I won't drink from the stream it's run off from the road so it's got oil and trans fluid and **** in it even if it's parts per hundred thousand or parts per million it's unhealthy without being distilled.. I'll still use a carbon and sand filter on that water.
Its like two or three feet wide, IDK how deep, but it never dries up because it's filled from a lake. Its in a like ten or twenty foot wide valley type of thing which turns into swamp in lots of rain so I'll frame out a bottle neck, put some concrete squares like one foot part on each side of the river so the water velocity increases for the water wheel, build a bridge over the whole swamp around that as a footing and put the water pump upstream and the sewage dump down stream. Some **** and piss is nothing compared to the oil run off
โFeb-05-2018 02:09 PM
โFeb-05-2018 02:03 PM
Caleb Volksa wrote:Really?
โFeb-05-2018 11:07 AM
โFeb-04-2018 09:14 PM
โFeb-04-2018 04:52 PM
โFeb-04-2018 03:42 PM
โFeb-04-2018 03:35 PM
โFeb-04-2018 03:20 PM
