Raising Rear On Diesel Pusher
novi2some
I am considering to buy a Winnebago Journey 40U. I have a steep driveway, 5 degree slope. The salesman, who knows my driveway, said I should not have an issue. I was wondering if there is a modification to the rear air suspension to raise the rear to help in clearance. Is there?
Happy Campers Since 1980 and still kicking.
12 REPLIES 12
dkreuzen
If the coach has AIR LEVELING it will have controls to raise and lower every corner. I use the feature to lower my coach so I can get it in my garage.
Dennis
2012 Monaco Knight 36PFT
2019 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon on 2007 16' Car Trailer
obgraham
The salesman'e opinion is irrelevant. Take the rig to the designated driveway and try it. Either it'll drag or it won't.
The full width mudflap will likely bottom out before the rig itself. That can (and should!) be easily removed.
J_R2
Can you back it up the driveway.
Ron & Joanne 06 Revolution LE 40E
bluwtr49
novi2some wrote:
What is the concern is the approach. The driveway can not be changed.
When your front wheels start up the driveway, the back end gets lower to the ground until the rear wheels start up the incline...and could scrape. Your coach is 40 ft so the front wheels have to go a long ways and the rear end keeps getting lower to the ground.
I'm cut in a driveway to the new RV barn and the excavator guy came back 2X to get the slope and approach angle correct so only the flap brushes the ground when I back in.
I didn't help that the road has a pretty good crown which made matters a bit worse.
The only thing you can do is try it and see. If it works fine...if not things get a bit more complicated.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
novi2some
Phil___Stephie
Can you reconfigure driveway?
Phil & Stephanie Grey
"Partners In Life"
2016 Allegro 36LA
2007 Chevy HHR
Yorkies; Paisley Marie & Opie Taylor
bluwtr49
Usually the grade isn't an issue, it's the approach angle. The rear will want to drag on the street.
Dick
novi2some
I will test out the motorhome on my driveway before deciding to buy. The salesman has already agreed to it. Thanks for the info on checking out a heavy truck place to see about overriding the ride height valve.
noteven
Hi novi2some - it might be worth asking a heavy duty truck repair shop if they can equip your MH with an air suspension over inflation valve like heavy duty trucks have for certain applications. The valve is controlled from the driver seat and allows the suspension ride height to be raised (up to 4") for uncoupling trailers that don't have jack style landing gear, or clearing high crowned places with lowbeds etc.
Fishinghat
No, there is no easy way to raise the rear of your coach.
(Some coaches have an air leveling system where they can dump the airbags to temporarily lower the coach a few inches while the engine is running, but this is of no help in your situation.)
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
camper19709
x2. Take the salesman with you on a test drive including your driveway.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
CA_Traveler
First things first: Take the rig and salesman to your drive. Keep in mind that it's likely not loaded with cargo.
2014 Grand Cherokee Overland
Bob
