โNov-20-2016 05:52 PM
โNov-21-2016 04:51 PM
dahkota wrote:
We have the RM1350. It works on 120V or on gas.
When driving, we run the fridge on gas. FYI, when the vehicle engine is switched OFF in Auto mode, the fridge will automatically turn off for 15 minutes. This is a safety feature to ensure that propane is not running while fueling (the fear is that gas fumes may get into the vented area and ignite). So, running your RM1350 while on the road is safe as long as Auto mode (not Gas mode) is engaged. This is called "Temporary Gas Lockout and can be found in the manual.
During the summer, the fridge runs warmer while driving than while sitting and can get up to 38 degrees. During the winter, this is not the case and we typically see no rise in temp.
โNov-21-2016 04:06 PM
โNov-21-2016 01:56 PM
โNov-21-2016 01:54 PM
Canadian Rainbirds wrote:
Years ago we stopped in Los Mochis for fuel and lunch. As soon as we stopped I got out to turn the propane on. I was hit in the face with a blast of propane. A bronze (or brass) fitting had ruptured.
Now we have a good inverter, good batteries and 420 Watts of solar so run the inverter for the fridge while we are driving. With reasonable sun there is always a slight gain in Amps to the batteries.
I have yet to meet a professional fire fighter who runs with the propane ON.
โNov-21-2016 01:32 PM
โNov-21-2016 01:29 PM
J-Rooster wrote:toedtoes wrote:Any fridge that I ever owned is or was a 2 way!
I believe nowadays most RV fridges are 2-way. That means they only run off propane or electrical. If you are shutting off the propane when you drive, then the fridge has nothing to run on.
โNov-21-2016 01:21 PM
โNov-21-2016 12:21 PM
โNov-21-2016 11:44 AM
โNov-21-2016 08:49 AM
Thank you for your responses. Yes, I was told not to leave the gas on while driving, so if it is a two way frige, it only makes sense it won't cool while going down the road. I will follow up with a dealer when I can and confirm this.
โNov-21-2016 08:04 AM
crasster wrote:
RV fridges have caused so many problems for us that we went with a dorm fridge that only ran on A/C. They really do freeze ice and keep ice cream cold. They also have rock solid insulation. What works is to get several cold packs, freeze them solid, and when you drive just leave the cold packs around the fridge & freezer. When you get to your destination and plug in, it's cold again and will freeze the cold packs.
This really only doesn't work if you plan to boondock.
โNov-21-2016 08:01 AM
โNov-21-2016 07:54 AM
โNov-21-2016 07:43 AM
