Refrigerator Vent Fan
MikeDavies
Need to give our Dometic fridge more air flow.
Has anyone tried this type of fan?
http://www.ebay.com/itm/170942943306?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I'm trying to get away from having to install a fan in the vent on top of the coach.
Thanks
Mike
21 REPLIES 21
John_Wayne
That's the same as the one I'm using out side I just zip tied it at the out side bottom blowing up.I also have a small one just like it on the inside. Inside refrigerator temp. 34 degrees.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
stuplich
TechWriter wrote:
I used two, thermal-controlled 50 cfm fans under the fridge roof vent cover. These fans were 110V and powered by the outlet in my fridge compartment.
TechWriter
Nice....but, IMO, not as good, (energy wise), as a 12VDC fan, (or fans), when driving and/or boondocking.
Mel
'96 Safari, with 1 12V thermal-controlled fan
hottubkid
I took a piece of shelving unit and made a mount to attach two 30 CFM squirrel cage fans to the outside grill of the refer. This was three years ago. I lowered the numbers on the refer two numbers and has worked well for three years. Only problem I have had was the recall went off coming out of Yuma AZ. Learned that if I hold a strong magnet to the upper right corner of the recall it will reset itself. If it were to keep going off I would have a problem but if it resets you should be good to go.
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
MikeDavies
two travelers wrote:
I've been considering adding fan as well. With the roof vent mounting, how do you find a 12v line to feed it? We have a Norcold and I've been led to believe that there are no 12v leads on the back; nothing I can find in manual or circuit on back of fridge give any indication. Any suggestions are welcome. Thanks!!
Interesting. If you search on the different forums you will find lots of threads about the Norcold. What model is it?
two_travelers
MikeDavies
TechWriter wrote:
MikeDavies wrote:
Where are the thermostats for the fans located?
It's on the thermal controller which is located in the middle of the photo below with a red LED on:
BTW, up to 4 fans can be connected to one thermal controller.
Thank you,
I see it in the slide show pics.
I pulled the roof vent off of mine today to measure the opening. The way its designed, I'm surprised any air gets through there. Of course it has to keep water out. I wanted to use 2 computer case blower fans but I'm not sure they will work.
TechWriter
2004 - 2010 Part Timer (35โ€™ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ€™ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ€™ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
MikeDavies
Nice install. Where are the thermostats for the fans located?
Thanks
MIke
TechWriter
DISH TV for RVs
Chopperbob
I only have two on mine but they are on whenever
The reefer is on.
I do have 540w of solar.
Bob
Gjac
jauguston wrote:
I have 4 computer fans across the opening below the screen. Wires together and controlled by a button thermostat and 2 more in the side opening blowing up from the bottom also on the thermostat. I found button thermostats on E-Bay that activated at 10 degrees lower than the stock one and used one to replace the stock one and the second one for my added fans
We have one of the infamous Norcold 1200 LRIMSS 4 door refer/freezers that had the cooling unit fail. We had a Amish cooling unit installed and the fans are to help it as much as possible. It seems to work well.
Jim
Jim does the multiple fans across the top restrict the natural draft when the fans are not turned on (cooler days) of do they pretty much run all the time?
stuplich
352 wrote:
I use THIS ONEFuse protected for the RV and my kegerator. Thermostat was @ 35 and the installed fan brought it down to 23.
The OP is asking about a fan in back of the fridge....
However, one inside is not a bad idea.
I have one similar to yours and it improves cooling and helps prevent icing of the fins.
Mel
'96 Safari
352
I use THIS ONE. Fuse protected for the RV and my kegerator. Thermostat was @ 35 and the installed fan brought it down to 23.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Chopperbob
I think your write up was what inspired me,
Thanks!
Bob
