Refrigerator Vent Fan
MikeDavies
Need to give our Dometic fridge more air flow.
Has anyone tried this type of fan?
http://www.ebay.com/itm/170942943306?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I'm trying to get away from having to install a fan in the vent on top of the coach.
Thanks
Mike
21 REPLIES 21
jauguston
I have 4 computer fans across the opening below the screen. Wires together and controlled by a button thermostat and 2 more in the side opening blowing up from the bottom also on the thermostat. I found button thermostats on E-Bay that activated at 10 degrees lower than the stock one and used one to replace the stock one and the second one for my added fans
We have one of the infamous Norcold 1200 LRIMSS 4 door refer/freezers that had the cooling unit fail. We had a Amish cooling unit installed and the fans are to help it as much as possible. It seems to work well.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
MikeDavies
murphysranch wrote:
Why do we need to consider adding a fan to our refrig? Just wondering...
Absorption refrigerators don't work as well when it gets hot.
Heat builds up in the vent space behind them. Some installs are
poorly designed. The fan just pulls in more air to exchange heat
and makes the unit work more efficiently.
murphysranch
Empty nesters
2 cats
2 cattle dogs too!
Chopperbob
I just took part of the screen loose then zip Tyed it back.
No harm it's under the cover.
Bob
Chopperbob
I think it's been established that it's better to
Put the fan on top vs the bottom.
I waited a long time before finally reading
A really good write up on the subject.
Made it easy for me to finally do it.
Forget all the solar stuff just run it when it's being used.
MikeDavies
Chopperbob wrote:
Easiest is to zip tye a computer fan to the screen on top under vent lid. With something
Long run two wires down to the wire block
Put a switch there run it when the reefer
Is used. Works great. I used two Tyed together.
Bob
Thanks
I didn't want to have to cut the screen on top.
The fan in the link is a computer case cooling fan.
But it moves 29 cfm at max RPM.
Chopperbob
Bob
