Refrigerator
cruzkid
Hi all. Just turned on my frig because we are headed out next week and it will only work on propane. Will not come on with AC power. Checked the power cord receptacle and it has power. When put on auto mode. It goes right to propane. It sounds an alarm and flashes a NO sign when put on AC power. It is a Norcold 1200 4 door model. Does anyone have any suggestions?
6 REPLIES 6
cruzkid
Thanks to all you guys. This is a great forum. So much help.
dougrainer
JimM68 wrote:
If the fridge works on propane, then the 12v fuse and supply is good.
Does seem odd that it would fault so quickly on AC though.
WHY does it seem odd? Doug
JimM68
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
dougrainer
The 120 volt fuse on the Control board is blown. The odds are, IF it is blown, one of the 2 heating elements is shorting out. You replace BOTH heating elements if this is the case and replace the fuse. Doug
Executive45
Two things to check....
1. Turn fridge OFF
2. Open outside compartment door.
3. Find the black box.
4. At the bottom of the black box are two wires, a black and a white. Remove the BLACK wire for 30 seconds and plug it back in.
5. Turn the fridge back on and see if the problem is fixed...if not, see below.
1. Turn fridge OFF.
4. Note the position of all wires going to the black box. Cell phone pic is helpful.
5. Remove wires to black box.
6. Remove 4 screws holding the cover on the black box.
7. Remove cover
8. There are two fuses inside...one is a 12VDC fuse and the other a 120VAC fuse.
9. Using a meter, check both fuses. Replace the one that's blown.
10 Reassemble in the reverse order as above..
Good luck....Dennis
schlep1967
Check your GFCI breaker, probably in the bathroom or next to the kitchen sink. Part of a 110 AC outlet. It will have a test and reset button. Press the reset button.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
