โSep-08-2013 02:05 PM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โSep-09-2013 07:09 PM
msmith1199 wrote:
Holy moly that's a big TV! How do you get into the side cabinets? But this did just give me an idea. I was worried about being able to open my side cabinets. The doors swing up. If I go with the articulating arm mount I can actually get a bigger TV and just let it go in front of the cabinet doors because with the arm I can move the TV out of the way to open them.
โSep-09-2013 05:57 PM
โSep-09-2013 03:58 PM
โSep-09-2013 03:48 PM
โSep-09-2013 02:54 PM
โSep-09-2013 02:29 PM
โSep-09-2013 02:07 PM
Jack&Kay wrote:
On my Tiffiin there were 8" long screws on both sides holding the frame in. They were easy to get out. Sory yours were so hidden and it took so long, but you got it done and now you can move on. Pat yourself on the back for a job well done.
โSep-09-2013 01:47 PM
โSep-09-2013 01:31 PM
โSep-09-2013 10:14 AM
msmith1199 wrote:
Found this coil of wires behind the TV. There are two coax cables then some other cable with a large multi-pen connector on it. It had a piece of masking tape on it and written on the masking tape was "Do not use, inoperable." I'm not exactly sure what it would have been for. Maybe for the backup camera? But if so, where is the cable that works for the backup camera and how did they put in new cable without removing this cable? I'll have to figure this one out later. Anybody got any ideas what it is?
โSep-09-2013 08:14 AM
1fastdad wrote:
In the cabinet on the right there are virtical pieces of wood on each side that have to be removed(two screws on each side). Remove the door and latches and the top shelf will slide out to get to the plugs.
โSep-09-2013 07:53 AM
โSep-09-2013 07:51 AM
1fastdad wrote:Deano56 wrote:I respectfully disagree with this method of mounting. the steel frame was built to hold the weight of the large heavy TV and will do a good job of holding the new one. I don't beleive the cabinet facia will hold the TV for a long period of time going over rough roads.
I would discard the steel sides and make a bracket to mount a hanging tv mount, then make a wood box around that, or fill in the open area with a nice panel of wood with the bracket coming down through it.
โSep-09-2013 05:55 AM
โSep-09-2013 05:46 AM
