Replacement for generator hour meter
George_Beggs
The hour meter for my generator has died. It is a Hobbs LCD 12-48VDC
meter that mounts on the dash. My Bounder is 10 or 11 years old and I can't find a replacement. Does anyone know the correct part number?
Thanks in advance.
George & Linda
2007 Bounder 35E
Ford V10
7 REPLIES 7
STBRetired
crasster wrote:
I've always thought hour meters were kind of strange since they are so easy to "hack" for a dishonest person. Perhaps they are only good for your personal knowledge.
That's how I tell when it is time to service the generator. All I worry about is run time since last service.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
crasster
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
George_Beggs
Thanks everyone; I ordered one from Fleetwood.
George & Linda
2007 Bounder 35E
Ford V10
Sloop_Smitten
Hobbs Hour Meter
1992 Fleetwood Jamboree Rallye 24' M/H
Ford E350 Chassis, 7.5L Engine, E40D Transmission
My other motorhome is a 1978 Catalina 25 Sailboat
Cruising Califonia, Sailing the Pacific!
Hikerdogs
Is your hour meter digital or mechanical? If it's digital it may just be in need of a battery. Many of the digital meters need a backup battery to keep the display and memory alive. I have several on machines that use this feature. The battery supplied with the meter usually has about a 10 year life.
I recently had to change the batteries in 2 different meters. The batteries have to be removed and replaced within 15 seconds for the meter to retain it's memory. It isn't difficult to do if you have everything in place before starting. Unfortunately if the battery goes dead, or the meter is unpowered for more than 15 seconds the meter will restart with 0 hours on the display once the battery is replaced.
Hikerdogs
2013 Winnebago Adventurer
Ivylog
If you can't find the exact replacement I'd just mount/glue any 12V hour meter in a convenient location. Run the 12V wire from the old meter to the new plus a ground.
Upgraded with a 08 HR Navigator 45โ€™...
Trackrig
Type Hobbs hour meter 12V into Amazon a d several come up.
Bill
