Replacing bulb in outdoor light 2013 Elipse
Goldencrazy
I can’t seem to get the lens off to replace bulb on outside light. Any help?
6 REPLIES 6
Mile_High
Have you tried pushing in at the top and sliding the lens down? I'll have to learn I guess. Also, what bulbs do those take?
On edit: I wonder if those are actually LED. If they are the same as this light, the Chrome actually comes off the top to expose the screw holes for the whole light. They are sealed and not serviceable. Kaper II
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
shastagary
usually need to pry the lens out with a small thin knife. click link Removing the Lens
Goldencrazy
Mine has a chrome top and bottom part is lens. No place to squeeze. It is very firm. Must be an easy release if i can find it. It is the light for the outside above utilities. Same as door light.
bullydogs1
My old HR was that way, you had to squeeze lens top and bottom to move the tab from the lens out of the housing lock.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
Lwiddis
Good time to put in an LED.
Mile_High
I'm pretty sure you just squeeze it up from the bottom.
