Replacing TV on Triple E GT29
triboy
We have a new to us 2010 Triple E GT29DBS, I'd like to replace the 26" Jensen TV along with the stereo system. I'm having a tough time removing the TV from the surrounding cabinet, there is about a 1/2 inch gap all around between the TV and the cabinet, I've poked and prodded everywhere but no clear signs of where and how it attaches. I've even removed a couple of panels from the inside of the TV cabinet but still can't see any attachment points.
If anyone has any experience with the Triple E TVs your input would be appreciated.
Thanks
8 REPLIES 8
JohnJoanW
We also have a 2010 GT29 DBS. I would also like to have contacts to share information with. Could you PM me as well?
Be Blessed!
triboy
Got it out with the help from a shop. It was secured in with 4 bolts that were attached to a metal frame. I was able to get the top 2 bolts off from the access panels on either side of the TV but I was stumped after that. The shop apparently ended up taking down the rear part of the cab headliner to get access to the bottom 2 bolts.
Looks like a 32" will fit in quite nicely, a new TV will likely weigh about 1/2 of the Jensen so the industrial strenght frame will be replaced as well.
I'm considering replacing the RCA audio unit, wondering if anyone has swapped theirs out?
Straycat2161 I'll try sending you a PM.
j-d
If you guys will "enable private messaging" you can correspond there and exchange contact info. Thought I'd better find it...
1. My Forums
2. My Profile (requires password)
3. My Preferences
4. Scroll toward bottom
Straycat2161
I also have a 2010 Regency 29 GT. While I have not attempted to replace the TV, I have made a few other modifications. If you haven't done so, I would suggest you call the Triple E factory and speak to Brad Wall. They have been very good at getting back to me with answer's to my questions. It will probably save you some time and effort.
Since we both have the same RV (and there does not appear to be many of us) I would like to stay in touch with you to discuss any issue's or modifications in the future. Not quite sure how to get you my personal e-mail address but I'll try to figure it it.
Good luck with your project.
triboy
Couldn't find any obvious screws other than 3 horizontal screws on each side that attach the side cabinets to the TV cabinet. Need to do a little more poking around tomorrow.
Harvard
Harvard wrote:
We have a 2004 Regency that shipped from the factory with the over cab TV. I personally pulled the TV and as I recall I had to access the TV anchoring via the top of a side cabinet. The wall of the side cabinets do not extend to the ceiling. This was 5 years ago and I cannot recall the details.
I took a look at the opening where the TV used to be. I notice there is a screw hole at a 45 degree angle at the bottom center of the cavity about 1 inch from the outer edge. I may of had to remove a screw from that hole, I just do not remember.
triboy
Thanks for the input, ours is the over cab TV as well. Unfortunately they've extended the side of the cabinet to the ceiling with no clear signs of easy access without pulling and digging stables/pins out. They did put in a 10X8 access panel on both sides of the TV but unfortunately they don't allow access the the rear of the TV. Might try prying things a bit, will likely need to do a little cutting of the cabinet frame anyways.
Thanks again.
Harvard
