Sep-21-2013 02:29 PM
Sep-21-2013 09:21 PM
Sep-21-2013 07:51 PM
Sep-21-2013 07:17 PM
Sep-21-2013 05:18 PM
enblethen wrote:
Check your fuse panel. Some rigs have separate fuses for the trailer connector.
Turn signal indicator on with lights, indicate a lamp outage.
Verify brake lights? Clearance lights?
Have helper operate lights. Verify that bothe sides of the rig are lighting up the same on each function. Headlights & clearance, turn signals, four way flashers and brake lights
Sep-21-2013 04:21 PM
Bud
USAF Retired
Pace Arrow
Sep-21-2013 03:48 PM
enblethen wrote:
Back up lights use a common source. Follow wiring between the two. Check connections where the trailer connection ties into the system.
Different rig then in signature? make, model, chassis would help. Sounds like Chev chassis.
Sep-21-2013 03:39 PM
Bud
USAF Retired
Pace Arrow
Sep-21-2013 03:27 PM
Sep-21-2013 03:19 PM
enblethen wrote:
Steady turn indicato would show you have a lamp outage on the right side. Yes, problem could be related.
Go under rear of rig and check to see how the lamp grounds are achieved.
Do you have turn indicators on mirros? What about mid side?
Back up lights is not a required lighting.
Sep-21-2013 02:42 PM
Bud
USAF Retired
Pace Arrow
