Rubber Spray Sealant
Ev
I have two leaks in my my roof vents I was thinking of using the rubber spray sealant for the time being until after our trip anyone ever use this product I am wondering how well it works.
Thanks
2002 Georgie Boy Landau 3402DS Ford V-10
18 REPLIES 18
Ev
Well the job is done used eternabond and it was easy to apply took about three hours to do the job I also used dicor around the smaller areas like the ladder,sewage vent tv antenna and radio antenna hope this cures my leaks and thanks to all who replied and gave your thoughts ๐Ÿ™‚
B_s_Bunch
It had holes in it and was letting the flies out I could have bought a new one for less money :B
Larry,Brenda,Travis,Jarred & MEME the Boston Terror:E TheBunch 2011 American Coach Revolution 42T:C The Double Wide
03_RoadKing
B's Bunch wrote:
I ruined a perfectly good screen door with that Sh(&. Ill never use it again:B
Why would you use this stuff on a screen door?
Jim and Deb
The Furchildren Abby and Baylee
USAF Retired
2001 Newmar Mountain Aire
MustangGT
LOL. You probably didn't follow directions to mount the screen door on the bottom of a boat. You can't blame anyone else for your lack of sense.;)
Mark, Jean, Paul & Lizzy (the mutt, RIP)
1997 Fleetwood Southwind Storm 34LS >
Thirsty, noisy & clunky. She ain't pretty, but she sure is fun!
"Aerodynamics are for people who can't build engines." Enzo Ferrari
B_s_Bunch
RV_daytrader
well, the two posters who actually used the stuff say it worked good!...the ones who never used it say it is junk!....and it is not like undercoating. Flexseal dries to a flexible rubber coat, undercoat is just spray on tar imo.
YODA...our lil Toyota!
1989 Toyota Seabreeze
MustangGT
I haven't used Flexseal, but it appears suspiciously similar to vehicle undercoat you can buy at all the car parts places for half the cost of the TV stuff. Eternabond tape is available at Walmart, marine dealers and RV/motorhome places. I swear it will last longer than most of us. the self-leveling caulk is also durable, but can be a mess. Plus you need a caulk gun. But sometimes its fun to make a mess.
mtrumpet
A consumer reporter on a local TV staion up here did a test on "Flexseal". According to their tests, it didn't do a darned thing as claimed on the TV commercial. Ended up with "two thumbs down".
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
vance
Used Flex Seal two years ago, no leaks, still looks like it did the day I put it on.
vance
2007 Coachman Encore
330 HP Mercedes
Honda CRV toad
"If you see our children, PLEASE don't tell them where we are"
Gjac
An older fellow that I know bought the Flex Seal several years ago and I was camping with him and it started to rain. He had tried to seal it with caulking prior to the rain, but the water was running all over his bed. He has an older Class C. I got up on his roof and sprayed it while the roof was still wet and was still raining slightly. It stopped the leak and is still holding two years later.
chuckftboy
Good Idea, use Eternabond. Flexseal might work as undercoating for the chassis but it won't stop a water leak.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Ev
Flyfisherman128 wrote:
Are you talking about something like Flexseal???? Are you kidding????
Yes like flexseal but after the responses I will not be using the spray stuff at all I think I will go with eternabond
ScottG
It's a short term fix at best and UV is going to eat that junk up fast. You don't wan't to make half-arsed repairs to a roof.
Flyfisherman128
