Apr-19-2024 02:49 PM
Our Onan Diesel generator starts up just fine but then stops after a couple of minutes. It will start back up easily but then dies again. It does not matter if it it loaded or not.
I'm not sure what to do. Any help would be appreciated.
Thank you,
Gridley
Apr-23-2024 04:41 AM
Are you not getting a code on your panel when it stops?
Apr-22-2024 04:15 PM
Too much oil. Drain a little out. Restart.
Apr-20-2024 08:07 AM
Sounds like the fuel pump
Apr-20-2024 05:23 AM
I had a similar experience a few years ago, not sure if this will apply to you or not. I was performing the annual maintenance on my AquaHot and for one reason or another, decided to start the generator (12500 QD in this case). It would run for a short period (1 - 2 minutes, perhaps) then stop. I restarted it and it repeated the same behavior. I may have done it once more before the real head scratching started. It then occurred to me that it was drawing air from the open end of the filter housing on the AquaHot (as I had the fuel filter off the unit as part of the annual maintenance). I replaced the filter and the "issue" was resolved.
Apr-19-2024 03:48 PM
change the air filter; change the gas filter.
