RVi2 Brake Unit
tunabob
We received a RVi2 brake unit with the 2014 CRV we purchased. The CRV was pulled behind a class A using this unit. It is all pre wired I believe, but I need to change the plug on our class c from a 4 wire plug to possibly an 7 wire, the CRV has a 7 wire male plug at the front now. I have determined that there is a dedicated 12 volt and ground wire going from the battery to the 7 way plug. Any advice or drawings would be great? Thanks.
2 REPLIES 2
CA_Traveler
If you want the charge line then add it to the MH. It wasn't needed on our CRV.
Prewired does not mean it's compatible with your RV for the lights as sometimes some additional equipment is required, not a big deal.
2014 Grand Cherokee Overland
Bob
bobndot
If u call etrailer, a tech will run you thru it.
Also, many youtube videos as well.
https://www.etrailer.com/faq-wiring-7-way.aspx
