โOct-12-2013 02:34 PM
โOct-14-2013 06:30 AM
jhilley wrote:
I always back in so that exiting in an emergency is easier. You have to back up to get out any way. With the mirror pulled in maybe it isn't useable. Hope his wife is better at guiding than mine is.
โOct-14-2013 06:22 AM
Mr.Mark wrote:Pauljdav wrote:
Believe it or not backing in would be easier. ...snip....an inch on each side.
Pauljdav, I just don't see how backing in is easier, especially, for the OP and his circumstances. His tight spot is at the back of the garage with only an inch on one side. His turning wheels are obviously in the front which will make it much easier to correct an error as he reaches the tight area.
.....snip...
This guy (OP) has no room for error.
MM.
โOct-14-2013 06:14 AM
โOct-13-2013 07:27 PM
โOct-13-2013 11:33 AM
โOct-13-2013 11:18 AM
โOct-13-2013 10:52 AM
โOct-13-2013 09:16 AM
โOct-13-2013 09:01 AM
Pauljdav wrote:
Believe it or not backing in would be easier. I had a very tight parking spor with my first MH. Now I have a trailer and I almost never park my dually nose first. I always back in. Try it in parking spots at the mall and you will see what I am talking about.
My neighbor has a super tight spot and he always backs in. I swear the fence he pulls through is less than an inch on each side.
โOct-13-2013 08:44 AM
โOct-13-2013 08:17 AM
โOct-13-2013 07:20 AM
tandkj wrote:
Folks, he didn't pull in he built the structure around the parked MH. Next time I want to see him back in and then get out.
โOct-13-2013 07:16 AM
SCVJeff wrote:
The one thing that will KILL you is having a dead battery while in the garage. ............clip.... consider a watering system for the batteries so you can keep them topped off without needing to pull out the coach.
โOct-13-2013 07:14 AM
Mr.Mark wrote:
Jeff, I bet the previous owner backed his unit in so the sewer is on the correct side. With the space being so tight for your coach, I don't think I would attempt a 'back-in'..... and, you would not be able to get out of the coach anyway as the door would be so close to the wall.
Mark
โOct-13-2013 05:45 AM
