Feb-24-2014 02:26 PM
Feb-25-2014 01:04 PM
Feb-25-2014 01:03 PM
Handbasket wrote:
I had a squirrely-driving '99/00 Dodge 3500 Ram Van class B early on in my RV'ing. It had about 55k miles on it when I tried a Safe-T-Plus on it. About 500 miles later, the power steering pump failed totally, with no warning, just after getting off a curvy stretch of the Blue Ridge Parkway. I can't prove a link, but I have no doubt the S-T-P caused the failure. It had made _no_ difference in the driving issues I was trying to fix.
Feb-25-2014 10:14 AM
Feb-25-2014 09:44 AM
txhood wrote:
My camber is set at 3.6. The alignment shop refused to set it any higher. The mechanic said it would cause the steering wheel not to return to center after turns if it was set at >5. They said it met Ford specs and that was all they were willing to do.
Feb-25-2014 09:11 AM
Feb-24-2014 05:51 PM
Feb-24-2014 05:45 PM
Feb-24-2014 05:42 PM
Feb-24-2014 05:41 PM
Feb-24-2014 03:35 PM
Feb-24-2014 03:31 PM
Harvard wrote:txhood wrote:
The front end alignment has been checked and the tire pressures are correct.
What was the front end caster set at? Should be > 5 degrees for best highway speed handling. IMO
Feb-24-2014 02:37 PM
