Ship RV to europe
workhardplayha1
What does it cost to ship RV to Europe (and back)? I know this is a very general question. I am not sure where we will be going or when we will do it. 28' class A
If you have done it how big is your unit and roughly what did it cost.
13 REPLIES 13
msmith1199
Tripalot wrote:
msmith1199 wrote:
Somebody got an RV onto a Cruise Ship?
Apparently so - it was a repositioning cruise so not a lot of port stops
I was just curious because I've been on cruise ships I wouldn't think most of the have the ability to store and RV anyplace. Unless it was a ferry boat type cruise ship.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Tripalot
2014 Triple E Regency GT24MB (Murphy Bed) with all the good stuff
towing a 2016 Jeep Cherokee TrailHawk
Berkley, the amazing camping cat missed dearly (1996-2012)
havasu
We had friends who bought a Georgie Boy and shipped it from NY to Liverpool - around $4500 at the time. They had to pay taxes when it arrived in port and then it cost a far chunk to have it converted to UK regs - the worst part was installing the seat belts which did not meet UK requirements and ended up with a 6" * 10" steel plate fitted to the outside of the RV on both sides!
Added to the impracticality of driving a US spec RV on narrow UK roads and the $10 a gallon gas, it's cheaper and easier to buy a UK spec Class B+ on a Mercedes Sprinter chassis.
workhardplayha1
Ok looks like I better find a plan B. Thanks for the information.
msmith1199
I don't think there are too many motorhomes (if any) that will fit in container. Unless they have mombo sized containers that I've never seen before.
tatest
About $5000, more or less, depending on your ports and where you are going, and how you want to do it, how soon you want to get it. That's my current guess, based on past experience moving around as an expat worker. That would be container shipping, delivery within a few weeks of dropping it off. At that price, you (or your agent) needs to be there to receive it, and deal with customs, when it arrives.
You can make that range about $3000 to $10,000+ in you want to include the extremes, from a roll-on to a tramp steamer with delivery whenever it gets to your port, to air freight at the other end of the scale. For a motorhome, maybe a whole lot more for air freight, as it may not fit through the door of the freighters used on regularly scheduled routes, and could require a military-type cargo plane.
There are also costs of preparation for shipping, then preparation for use. Motor vehicles usually have to ship dry, and without other goods (like personal effects and camping gear). Not always, because there are drive-on carriers, but they are not going to put your motorhome into a container or cargo hold full of fuel.
There may also be substantial customs bonds required, depending on the destination, for some countries possibly as high as the local value of the motor vehicle. That can also come up when you drive in to certain countries, at discretion of local officials. Most of western Europe, within EU and Schengen, is probably not too bad on customs once you get in, but watch out for places not part of the customs unions.
Then you have to get it back to the U.S., so double the cost, and maybe the hassle. When I moved to China, they didn't even break the seals on the containers. When I came back, ICE went through everything. Fortunately, I had good agents receiving for me.
There are a number of autombile shipping agents on-line, most handle just about anything. Any could give you a quote if you are ready to say what, when, where and how, and they will help you understand the details.
Tom Test
Itasca Spirit 29B
msmith1199
Tripalot
You might want to check with some of the cruise lines. I once read an article that they take freight on re-posistioning cruises. Whoever wrote the article used this method to get their RV to Europe as it was the cheapest way to get it there. If I have time over the weekend, I will try and locate the information.
crasster
Honestly, if you have the dough, it may be cheaper to buy a nice used coach over there and sell before you leave.
Renting RV's is EXPENSIVE.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
kevinbti
Read this today
http://www.smithsoverland.com/travel/publish/article_188.phphttp://www.smithsoverland.com/travel/publish/article_188.php
W4RLR
Thngs that don't work on a U.S. spec RV when taken to Europe:
Television - No television reception, either over the air or via satellite. The standards are different.
Radio - Tuning is different, 9 khz spacing for AM, 10 mhz spacing for FM, so you will see frequencies like AM 873 and FM 100.2. If you have an analog radio tuner, you will be fine, a tuner with a digital tuner MAY work if the radio can be switched between European and U.S. standards. Not all digital tuners will work.
Electricity - U.S. standard is 120 volts, 60 hertz. European standard is usually 220 volts, 50 hertz. Analog clocks will lose 10 minutes an hour, IF you step the voltage down with a step down transformer. Your microwave will not be happy.
LP gas - European filling nozzles are different. SOME LP gas retailers, primarily those close to the dwindling U.S. military presence, have adaptors.
Fuel - be prepared for $8 to $10 a gallon fuel costs.
Size of rig - A big class A will not fit on many urban streets in Europe.
Taxes - Be prepared to post a bond with the customs authorities. This bond can equal the value of the rig or more.
Shipping - several thousand dollars each way, and several weeks to transit the Atlantic both ways.
Not that I mean to disuade you, many people do bring RVs from the U.S. to Europe. You would have more success with a towable in my humble opinion, having lived in Europe and rented European "C" class equivalents for my vacations for several years.
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2008 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?"
Tom Clancy
I_am_still_wayn
There is more than just shipping the vehicle to Europe. Licensing, insurance, and converting it to whatever government requirements are necessary makes this a project requiring considerable research and money. Remember, your USA RV will not connect to European electricity.
Renting overseas is a much more viable option.
yrusoslo
Hello, check on the internet, it might be better renting one there.
