Shore Power Issue
Xlerator
05 Pace Arrow 37C, started my generator while on shore power, now I've lost 1 leg of my 120vac. Everything fine at the plug, at the main inside the coach 120vac on one leg, 33vac on the other, checked to neutral and ground. Gen set powers everything fine. Any ideas where Fleetwood ties the shore power to the gen set power? It's got to be a connection issue on the bad leg,I don't feel like running a new service yet! Any help would be great.
9 REPLIES 9
Xlerator
Thanks to all for the info, transfer switch on a 2005 Pace Arrow 37C is located under the closet drawers on the right side. It was a simple open contact on the shore power relay, a shot of contact cleaner and works like new. Thanks again for the help!
alkillion
Try to follow the power cord as it goes inside the coach. Xfer should be the first box the cord goes into.
Mine is in the bay that the power cord stows in.
If you decide to open it up, double check both shore and gen power are off!
Good Luck
May the Forza be with us!
2014 Winnebago Forza 34T
340 hp Cummins
Allison 6 speed
2006 Jeep Wrangler toad
SacsTC
Xlerator wrote:
Any idea of where the transfer switch is located. My coach does have the 50amp Intellitec EMS model 900.
The above caught my eye. Behind the cover over the circuit breakers, you will probably find a small circuit board for your Intellitec. Pull the onboard fuse, leave it out for approx. 60 seconds and replace. This will probably solve the problem. Also gives you a chance to tighten all wire connections while you are in there.
About page 6 in this pdf is a pic of the circuit board showing the fuse I'm talking about. There is also a troubleshooting section.
1999 Damon Daybreak 3270
2015 Jeep Cherokee Trailhawk
I was a good kid, now I'm making up for it
doxiemom11
Ours is in an outside bay - drivers side rear bay
Alan_Hepburn
In our 2007 Bounder 35E the transfer switch is under the computer desk in the bedroom. You have to remove the drawers to get to it...
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
teddyu
A friend has an older Damon,and the transfer switch was under the rear closet. JM2¢...
Ted Fulltiming in the DreamCatcher a
2008 Challenger 371PE on F53 w/ 2010 Cobalt
R'V there yet?
wildmanbaker
It's usually behind your AC breaker box.
Wildmanbaker
Xlerator
teddyu
Sounds like the transfer switch is partially hung up (one leg) in the generator position. JM2¢...
R'V there yet?
