Slideout Problem
shooer2
When I left campground the slideout came in OK. When I got to the next camping spot the slideout would not move. Could this be the in/our switch.
12 REPLIES 12
Goldencrazy
In my Winnebago the slides work best with engine running but will work without. Emergency brake on? I forget that all the time.
10forty2
Like said before, if the main engine's running, the slide won't work. If you didn't have the engine running, and the slide motor won't turn...then start simple and work your way up to complex. Check to make sure that you haven't accidentally disconnected the wire going to the motor. On mine, the wiring harness hangs down slightly below the motor and it's easy to hang the wires with "stuff" that I'm putting in the storage bin. Next, if the wires are connected properly, then you'll want to check with a voltmeter that you are actually getting voltage to the motor. Disconnect the plug and insert the test probes while someone activates the switch inside. If no power, then go to the fuse panel and look for a blown fuse or a tripped breaker. If you have power to the plug and the motor is still not turning, then the only other option is that your slide motor is shot.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
2gypsies1
The OP didn't post his fix. That was someone else. ๐Ÿ™‚
OP? Where are you at this point?
Full-Timed for 16 Years
.... Back in S&B Again
GPWayne
Thank you for posting your fix.....Thanks for helping us all!
Peg_Leg
I thought I had a bad switch. After several hours of troubleshooting I found a bad circuit breaker. I could measure 13 plus volts through out the system but the breaker just couldn't pass the amperage. It didn't kick out either. It was a test light and not a VOM that saved my bacon.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
2gypsies1
Some won't operate until the engine is shut off. Did you possibly try while it was still on?
robsouth
Dead house battery?
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
shooer2
Motor not turning.
newman_fulltime
if the motor is turning its a good chance the bolt broke that attaches it to the mech its a grade 8 bolt 2 " byquarter with washers and a lock nut behind the drivers front tire look up there a trap door to access it
shooer2
Electric motor pushing the gears on the slide. On a Holiday Rambler.
Crazy_Ray
It also would help WHAT TYPE MH you are talking about.
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
carringb
Could be. Also could not be. What slide out system do you have?
2014 ORV really big trailer
2015 Ford Focus ST
