โMay-28-2016 06:41 AM
โJun-15-2016 10:40 AM
โJun-14-2016 12:03 PM
โJun-14-2016 11:59 AM
โJun-13-2016 01:44 PM
โJun-11-2016 08:15 PM
โJun-11-2016 11:21 AM
ron.dittmer wrote:
Baja Man,
I understand you are retrofitting your rig to accommodate a spare tire. I like your plan to mount the tire under the rig behind the rear axle. I assume you verified that you have enough room underneath and have a good place to mount the spare tire winch.
As far as tire-changing tools are concerned, I purchased a 30" long 3/4" breaker bar, a 3/4" extension for the dual rear tire lugs, and the right size 3/4" deep impact socket. The extra long 3/4" bar is strong enough to stand on if necessary. I found everything cheap for sale on the internet with cheap or free shipping.
I work on many different vehicles at an automotive charity. The best professional grade impact tools cannot loosen the worst of stubborn lug nuts on simple cars, and stubborn E350/E450 lugs would be worse yet. An extra long breaker bar is the only means to break stubborn lugs loose, and an extra long 3/4" bar will support the weight of a person standing on the end of it.
โJun-10-2016 08:32 AM
Baja Man wrote:
My Ford E450 chassis does not have a factory one installed underneath behind rear axle. I would like to install one in that location. Are they available from Ford or another source?
โJun-09-2016 04:42 PM
All58Parks wrote:
Going without the spare would be very ill advised. I remounted my from the rear bumper to an under-the-frame mount, right behind the axle. Bought the mounting kit on Amazon for something like $150, was easy to install and works great. Obviously, you're still carrying the weight though.
โJun-09-2016 08:13 AM
Baja Man wrote:
ron--
Yes...I have about 36" between the chassis and a large cavity between the axle and the rear bumper. Spare tire is about 30" in diameter.
I'm carrying the 1/2" impact only for assistance and efficiency. I plan on also carrying similar tools to the ones you mentioned for manual use.
I am considering the TECA winch. I will weld 3 angle iron pieces to chassis (from one side to opposite side). Center one for winch and the two others to stabilize the wheel/tire once it reached the winch and tops out.
โJun-09-2016 07:49 AM
โJun-09-2016 05:16 AM
โMay-30-2016 06:26 PM
โMay-30-2016 04:26 PM
โMay-30-2016 03:27 PM
