Spares stored underneath tend to get ignored. Pull it once a year and wash it thoroughly to make sure dirt isn't collecting in the rim and rusting it, and of course to check inflation. I wished my spare was underneath, but WBO put the tanks in the rear, widest part of the frame, only place the spare will fit. I measured the big void behind the differential and it is too narrow, sigh.
To answer your question about the availability of the tire, I think you have a LT215/85R-16 which is a fairly easy to find tire. If you want to keep it and expect to use it, make sure you have the tools to do so. Long ยฝ drive breaker bar, 16 or 18 inch extension, 19mm socket, and remove the jack and make sure it actually works (its a two stage, so it goes quite high). DO NOT depend on roadside service to know the ins and outs of changing YOUR tire/wheel. You need to know this, even if they are changing it. For example, underneath the lugnuts there are conical split washers that can easily become lost during a roadside tire change. Make sure they get properly reinstalled (steel wheels, not sure what they use on Aluminum rims).
Charles
2007 Winnebago View 523H on a 2006 Dodge (Daimler-Chrysler aka Mercedes) Sprinter 3500 chassis (T1N). Bought Sept 2015 with 18K miles on it, Prog Ind HW30C, Prog Dymanics PD4645, Chill Grille, PML/Yourcovers.com deep alum trans pan, AutoMeter 8558 trans temp gauge, Roadmaster sway bar, Fantastic Ultra Breeze hood, added OEM parabolic mirrors and RH aspherical mirror.
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
