Smelled gas and ran my finger around the joints, assuming that's where the leak was. Turned the valve off and then saw the spray come out from a crack adjacent to the 1/4" supplemental connection on the body of the stay-a-while. Probably from 9 years of bouncing around but assumed it would last much longer.
I cut a piece from a 1X4 that was a slight press fit under the Stay a While T. I used some silicon adhesive underneath make sure it didn't vibrate out. Lasted about 11 years with no problem.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
A number of years ago the manufacturing of these items, along with many other similar components, moved to Mexico and in some cases the Pacific Rim countries. The quality of the brass castings went down badly. Cracking in the cast parts is not unusual since then, along with the quality of the machining of threads, etc. opening the door for leaks.
Since the fittings mentioned by the OP is installed on the high pressure side of the supply system it is exposed to pressures of 250 psi +/- and will leak much easier than the items on the low pressure side where pressures of about 6 ounces per square inch are normal.
These go by a number of names, another popular one is extend-a-stay
It is a brass combo valve assembly that goes between the propane tank and the RV's propane regulator. They allow you to use an external portable propane tank to supply propane to your RV, they can also be used to operate a BBQ grill from the RV's propane tank / tanks.
This is the one I installed after a valve on the old one on my motorhome developed a slow leak
