Front caster is a common cause.
Also check your front end weight and tire pressure, and adjust the pressure to be right for the weight. If there's not enough weight on the steer tires, that can be a problem; shifting weight in the RV could help with that. Likewise, if the tires are inflated well above what's needed for the weight, it can make for poor, imprecise handling.
