Jul-22-2023 09:30 PM
Aug-08-2023 07:37 PM
Aug-01-2023 06:16 PM
Jul-31-2023 08:18 PM
oldave wrote:
I see some RVs with extreme overhang at the rear. That could exacerbate any overloading because that's where the extra weight is likely to go.
If you have ever pulled a trailer that was way heavy in the rear then you know how important weight distribution is.
Acceleration shifts the weight even more towards the rear that's why the wobble kicks in.
Depending on the location of the tanks those could play a big part.
BTW, I consider those tires unsafe. Even if they were new, 4 to 5 yrs
puts them near the end and sitting all that time cannot be good.
I would replace them all. Rearrange your weighty items and go somewhere.
Jul-25-2023 05:09 AM
Jul-25-2023 03:46 AM
Nakinto wrote:SuperBus wrote:
Certainly the other factors you mentioned could be in play, but I would also recommend checking out your steering stabilizer(s) if equipped.
I wish there was a stabilizer! That thing really helps with hitting bumps or potholes with only one wheel!
Jul-24-2023 08:15 AM
Jul-24-2023 03:34 AM
Jul-23-2023 04:32 PM
Nakinto wrote:RLS7201 wrote:
Holiday Rambler Alumalite 1986, came as a Travel Trailer, class C & class A.
Assuming you have a class A MH, it would be on a Chevy P32 chassis.
That chassis has a bell crank in the steering linkage that was not the best when new. Have some one shake the steering wheel and see if the bell crank moves up and down. If so, replace it with a Bell Crank from Super Steer.
Richard
Really? I didn't know there was a bell crank, I don't have anyone around right now to do anything, but I checked and there sure is a bell crank. Thank you for the link also. Ill ask a friend if they can come over tomorrow and we will yank a bit on it see if there is anything loose there. I am also going in for a tire inspection tomorrow so hopefully whatever it is is found out!
Jul-23-2023 01:05 PM
Nakinto wrote:
ALL the tires? YIKES! Well, going in for a tire inspection tomorrow anyway so we shall see!
Jul-23-2023 12:46 PM
Bruce Brown wrote:
If it's sat for that long I would lean hard towards it being the tires - they don't like to sit that long without moving.
Once they start wobbling and/or bouncing they normally don't stop until you slow down, as you noted.
Jul-23-2023 12:45 PM
Jul-23-2023 12:40 PM
Richard
Jul-23-2023 09:08 AM
Jul-23-2023 04:23 AM
