Still having a charging problem
AL49er
Hi still having a charging problem with my 2004 country star 3705 does anybody have a wiring diagram of the charging system for this RV I would like to know where the positive side goes to the coach batteries. And the ground side goes from the batteries to the rv.
Alternator was rebuilt the by directional isolator relay delay diesel โ€“ two was replaced. I think it's in the ground wire somewhere when you alternator in the batteries thanks for any of your help Al.
4 REPLIES 4
sjholt
Maybe he is having problems with the chassis battery keeping charged?
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
FIRE_UP
Yeah, me three on the don't understand the last two. But, typically, the grounding for both the chassis and house batteries go right to the frame, fairly close to the batteries themselves but, not always. As for the positives, when it comes to the house batts, the positive may have at least two large leads from the batteries.
One will go right to the inverter or, inverter/charger. The second one should at least go to a junction block where from there, it gets distributed to various fuse panels, relays and such to power up the coach's side of 12V ops. And, depending on the particulars of the make and model of the coach, you might have a third lead that will go to the starter on the generator. That way, if the chassis batteries are dead from sitting or, whatever reason, the generator should be able to start and, with the help of a charger of some sort, (many coaches, year/make/models are not equipped from the factory to charge the chassis batteries while on shore power or, generator power)be able to put enough charge into the chassis batteries to fire the beast up.
And of course, many coaches have capability of both sets of batteries being linked together via the "Battery Boost solenoid" which is activated by the toggle on the dash. I don't know if any of this helps but, I thought I'd throw it in for good measure.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
PaulJ2
ScottG wrote:
I don't understand your last two sentences. Can you proof read and clarify?
I'm not sure either but maybe---Alternator was rebuilt and bi-directional delay relay was replaced twice. Thinks it might be a ground wire problem when engine starts and charging should begin but doesn't?
ScottG
