Dec-21-2014 10:14 AM
Dec-22-2014 03:54 PM
TechWriter wrote:midnightsadie wrote:
I don,t think a dealer will admit to anything. something like this... we never heard of that happening before.
I've heard it happen in Newmars with Intellitec slide controllers (like my 2001).
Many have speculated on the cause (electrical transient, fluorescent lights, etc).
It happened to me when I plugged in one of those electric bug zappers -- the living room slide just started coming in on its own.
Since then, I (along with other Newmar owners) just remove the slide out fuse after extending the slides.
Newmar does not acknowledge the problem, but sooner or later someone will get hurt.
Dec-22-2014 12:13 PM
Dec-22-2014 12:00 PM
CA Traveler wrote:MR MAC wrote:Bad or low voltage batteries can cause strange and unexpected problems.
MH was in driveway about a wk., went in and turned on bat switch to on position, so as to turn on some lights, after a few seconds main slide went out, tried to bring in, came in half way and went out again. Did this a couple of times, then wouldent move at all. MH was not plugged in, ran gen. charged up batt. Now all is well-strange? Don't know if this could happen when driving, or if I had lock bars in place. Think I'm calling dealer. (2014 Coachmen Pursut)
Have your batteries load checked and then keep them charged. The batteries should also be charging when you are driving. If you can't plug in then use or install a full battery disconnect switch.
It's also possible that you have a defective part (circuit board, relay or???) or even a poor design that doesn't work well with low voltage.
Dec-22-2014 11:39 AM
Dec-22-2014 08:36 AM
Dec-22-2014 08:20 AM
Dec-22-2014 07:25 AM
Dec-21-2014 01:39 PM
Dec-21-2014 12:30 PM
Dec-21-2014 12:18 PM
