Thor Fourwinds V10
edstep
I am looking to purchase a 2011 Thor Chateau 29' It has a V10 305 and supposedly will tow a toad 5000 lbs
My question is how would a rig like this make it out west in the mountains
Thanks
3 REPLIES 3
pauldub
Just don't expect it to go up mountain passes like a car does. Folks from the flatter locales don't always understand this. Also, don't drive down the mountain like you're in a car or you won't have any brakes when you need them most.
Nevadastars
Our 2010 Chateau 25c (27ft overall) pulled our 4000 lb toad just fine over the numerous mountain passes here in Nevada.
2016 Forest River Wildcat Maxx 262RGX 8,268 UVW 11,754 GVWR
2007 Ram 2500 QC SB 4x4 Smarty tuned 5.9 Cummins
B&W Turnover Ball & Andersen Ultimate
kalynzoo
The Ford V10 performs fine in the mountains of Southern California...Grapevine, Cajon Pass. Let me expand a bit on that: I could tow my previous SouthWind and 3000lb toad over these mountains at 50mph...if I lost momentum I could regain about 45 mph on the real steep grades. However, just because they stick a 5000lb hitch on the RV that does not mean it will perform or be safe with that load. Check the Gross Vehicle Combined Weight Rating, and subtract the actual weight of the motorhome. It will give you a better idea of what can be towed.
