Thor Vegas, Rear bumper weight strength?
jolooote
I have a new 2015 Thor Vegas 25' Class'A' motorhome. I want to mount a spare tire & rim onto the rear bumper which is metal. I have the tire & rim and they weigh 80 lbs. Is the rear bumper strong enough to hold it? Thanks :@
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
8 REPLIES 8
J-Rooster
Not only should you call your RV Manufacture as Topflite 51 suggested, and also call your insurance company. The major Insurance Companies were a big influence on why RV's (and cars) don't have rear mounted spare tires anymore. If your vehicle is hit from the rear or you back into something there was way more damage caused from the rear mounted spare. You might not be covered if you install that tire! It's all about $$$!
MR_MAC
When I bought my MH Ford, F53, I talked dealer in to installing a spare up under rear, hey tried putting a crank up on, but tire would be too low, would mot fit between frame, so I took spare put into car trunk on plywood. My toad is a Ford fusion, the tire is heavy to lift, so I roll it up on tool box (5") put a moving blanket on car and flip it in. That is where it gona be when traveling, but happy to have it, its a 19.5 @32". One problem I took car spare out of compartment and put it on top of MH spare - Just in case? - Brother of mine spent night on road waiting for tire, not gona happen.
ROBERT L MC INTYRE
jolooote
topflight, I'm sorry you assumed we don't have "common sense". lol. Just kiddin, Friends?
Joe & Charlotte
topflite51
jolooote wrote:
topflight51, THAT will be my next move if all answers here are as helpful as you. Sorry if I was a bother to you.
Sorry. Didn't realize that a common sense suggestion would offend you.
:CDavid
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to fish
Simply Despicable ๐Ÿ˜›
Any errors are a result of CRS.:s
consumeratlarge
I asked Coachmen about mine, similar to yours. They advised against it. So, looking underneath, there are places to fasten one there. I was thinking about the tire winches on pickups, but these tires are heavier. So, maybe jack it up with blocks on one side then the other, etc, and fasten it rachet straps and a safety chain. Personally, I'm thinking that if I carry a small motorcycle and a cellphone, and can relax in the motorhome if I have to wait, maybe I don't need a spare to change myself.
Some have suggested tying one up in the back frame, but only the tire, not the wheel, then calling the cavalry, who will always have the tools, but not necessarily the tire, with them.
The weight is significant, since I will be at max tongue weight when pulling trailer, and don't want to max out the chassis overall. So far, no spare.
While driving for hours, I see lots of trailers with flats, but motorhomes on the side have the hoods open, never seen one with an obvious flat yet. Yes, I know, it happens, though.
Coachmen Pursuit 31BDP 2013, 300w solar, 1200w sine inverter, In-motion Winegard Dome sat. ant., L.E.D. lights, P2 brake controller, Yamaha 250 on back carrier, or pulling Stehl dolly with Hyundai Santa Fe
jolooote
Joe & Charlotte
rockylarson
If you have a 2 inch receiver then you might consider this option:
RV Spare Tire Carrier
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
topflite51
Why not be safe and call Thor and ask them?
:CDavid
